bgp default-originate
petercinvest
any difference between bgp neighbor default-originate and bgp default-information originate, are they the same? does bgp neighbor default-originate requires a static route? thanks
Reza Sharifi
Have a look at this post:
https://supportforums.cisco.com/discussion/11303951/difference-between-default-originate-and-network-0000-bgp
Hello
 With bgp neighbour- you can advertise a default to a specific peer without need for the rttr to check for a default route in the rib table before a default can be advertised.
the global command is to ALL peers and requires the forementioned checks
ree
paul
Kind Regards
Paul
I don't want to add a static ip route in my router 1, but I have a router 2, which is ospf neighbor to R1, in R2 ospf process, I use default infor orig. so R1 will receive a OE2 route
can I use bgp default-infor orig in R1 now?
