BGP neighbor over vrf
Mark Schwartz
I have been going over labs, etc., using GNS3 for MPLS, VRF's, etc.  Came across something that has me
scratching my head.
Simple two router setup.  Each router directly connected to each other via Gi 1/0.
I am providing all configs and relevant outputs at the bottom of this post.
Fist set of configs is extremely bare bones.  However, the non-vrf router (R2) says BGP status is 'Established' but the
vrf router (R1) says 'Idle'.  They are directly connected so I should not need any routes.
When I debug R1 it says: Active open failed - update-source NULL is not available, open active delayed
(see bottom of post for outputs).
Then I went a little crazy and used loopbacks with explicit static routes (second set of configs).  Here I can ping from
R2's loopback to R1's Gi 1/0 interface, but I cannot ping from R1's loopback to R2's Gi 1/0 interface (again, output provided at
bottom).  I simply do not see why connectivity is broken from R1 using the vrf.  The routing table on R1 shows a valid route
to R2's connected interface (and lo0 for that matter, but I can't ping loopback to loopback in either direction. Routing tables
on both routers show routes are present).
If I get rid of the vrf I can get it all working in 30 seconds.
I must be doing something wrong but I am at a loss to see what I am missing.
If somebody could please point out my error I would really appreciate it.
Thanks in advance,
-- Mark
R1
vrf definition BGP
 rd 1:1
 route-target export 1:1
 route-target import 1:1
 address-family ipv4
 exit-address-family
ip cef
interface Loopback0
 ip address 1.1.1.1 255.255.255.255
interface GigabitEthernet1/0
 vrf forwarding BGP
 ip address 10.1.1.1 255.255.255.252
 negotiation auto
interface GigabitEthernet2/0
 ip address 10.2.1.1 255.255.255.252
 negotiation auto
router bgp 100
 bgp log-neighbor-changes
 neighbor 10.1.1.2 remote-as 200
 address-family ipv4 vrf BGP
  neighbor 10.1.1.2 activate
 exit-address-family
R2
ip cef
interface Loopback0
 ip address 2.2.2.2 255.255.255.255
interface FastEthernet0/0
 no ip address
 shutdown
 duplex full
 ip address 10.1.1.2 255.255.255.252
 negotiation auto
 ip address 10.2.1.2 255.255.255.252
 negotiation auto
router bgp 200
 neighbor 10.1.1.1 remote-as 100
R1#sh ip bgp neigh
BGP neighbor is 10.1.1.2,  remote AS 200, external link
  BGP version 4, remote router ID 0.0.0.0
  BGP state = Idle
  Neighbor sessions:
    0 active, is not multisession capable (disabled)
BGP: 10.1.1.2 Active open failed - update-source NULL is not available, open active delayed
R2#sh ip bgp neigh
BGP neighbor is 10.1.1.1,  remote AS 100, external link
  BGP version 4, remote router ID 1.1.1.1
  BGP state = Established, up for 00:00:26
  Last read 00:00:26, last write 00:00:26, hold time is 180, keepalive interval is 60 seconds
  Neighbor sessions:
    1 active, is not multisession capable (disabled)
R1
vrf definition BGP
 rd 1:1
 address-family ipv4
 exit-address-family
ip cef
interface Loopback0
 vrf forwarding BGP
 negotiation auto
 negotiation auto
router bgp 100
 network 1.1.1.1 mask 255.255.255.255
 neighbor 2.2.2.2 remote-as 200
 neighbor 2.2.2.2 update-source Loopback0
  neighbor 2.2.2.2 ebgp-multihop 3
  neighbor 2.2.2.2 activate
 exit-address-family
ip route vrf BGP 2.2.2.2 255.255.255.255 GigabitEthernet1/0 10.1.1.2
R2
ip cef
interface Loopback0
 negotiation auto
 negotiation auto
router bgp 200
 network 2.2.2.2 mask 255.255.255.255
 neighbor 1.1.1.1 remote-as 100
 neighbor 1.1.1.1 ebgp-multihop 3
 neighbor 1.1.1.1 update-source Loopback0
ip route 1.1.1.1 255.255.255.255 GigabitEthernet1/0
R1#ping 10.1.1.2 so lo0
Sending 5, 100-byte ICMP Echos to 10.1.1.2, timeout is 2 seconds:
Packet sent with a source address of 1.1.1.1
Success rate is 0 percent (0/5)
R1#sh ip route vrf BGP | beg Gate
Gateway of last resort is not set
      2.0.0.0/32 is subnetted, 1 subnets
S        2.2.2.2 [1/0] via 10.1.1.2, GigabitEthernet1/0
      10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        10.1.1.0/30 is directly connected, GigabitEthernet1/0
L        10.1.1.1/32 is directly connected, GigabitEthernet1/0
R2#ping 10.1.1.1 so lo0
Sending 5, 100-byte ICMP Echos to 10.1.1.1, timeout is 2 seconds:
Packet sent with a source address of 2.2.2.2
Success rate is 100 percent (5/5), round-trip min/avg/max = 24/30/36 ms
7 Replies 7
eduardopozo56
On R1 (the vrf router) remove all the neighbor statements from the parent BGP protocol, all statements for the 10.1.1.2 neighbor should be inside the  "address-family ipv4 vrf BGP"
With the static routes, your ping is failing because you are not adding the "vrf BGP" to your ping command.
I just did your topology on a lab and had 0 issues.
Some of the config:
R1:
ip vrf BGP
 rd 1:1
interface Loopback0
 ip vrf forwarding BGP
 duplex auto
 speed auto
router bgp 100
 no synchronization
 no auto-summary
  no synchronization
 exit-address-family
R2:
interface Loopback0
 duplex auto
 speed auto
router bgp 200
 no synchronization
 no auto-summary
R2#sh ip bgp summ
BGP router identifier 2.2.2.2, local AS number 200
BGP table version is 1, main routing table version 1
Neighbor        V    AS MsgRcvd MsgSent   TblVer  InQ OutQ Up/Down  State/PfxRcd
10.1.1.1        4   100       8       8        1    0    0 00:05:33        0
R1#sh ip bgp vpnv4 all summ
BGP router identifier 1.1.1.1, local AS number 100
10.1.1.2        4   200       8       8        1    0    0 00:05:52        0
Eduardo
Do you know of a command equivalent of "sh ip bgp summary" that you can use for a VRF neighbor ?
I can never seem to find one ?
Jon
Yes, i did use it on my example, all the "vrf neighbors" are under the vpnv4 or vpnv6
It might change a little bit depending on the address family that you are using for the adjacency, you can start with "show ip bgp vpnv4 ?" and go from there
So you did, I should have read your response more carefully.
Many thanks
Jon
Eduardo,
1)  I am embarrassed by the ping error.  I know better than that.  I think I was just a bit
flustered by the BGP neighbor not coming up.
2)  After removing the neighbor statement from the parent it works.
Thank you!!
Sincerely,
Mark
Jon Marshall
Just to add to Eduardo's post.
It was actually working even with the error messages.
These are seen because you have, as Eduardo says, a neighbour statement under the main BGP configuration.
But the routes are still exchanged, I tested it in a lab.
When you did a "sh ip bgp summary" and it showed idle you were looking at the non VRF summary but your VRF peering was actually working.
That is why the other end shows up.
So it exchanged routes with or without the main bgp neighbor statement.
The only difference being without it, you don't get the error messages.
Jon
Jon,
Thank you for the explanation.  That helps.
Sincerely,
Mark
