BGP network x.x.x.x mask command
Denis Wahome
I am trying to configure BGP for ISP connectivity, when i enter the network statement under BGP the mask part does not appear hence the network is not advertised with the mask.
See attached config;
router bgp <OUR_AS>
bgp log-neighbor-changes
neighbor 192.168.100.1 remote-as <ISP_AS>
neighbor 192.168.100.1 description ISP_BGP_PEER
neighbor 192.168.100.1 update-source FastEthernet0/0.704
address-family ipv4
  neighbor 192.168.100.1 activate
  neighbor 192.168.100.1 soft-reconfiguration inbound
  neighbor 192.168.100.1 prefix-list DEFAULT in
  neighbor 192.168.100.1 prefix-list OUR-PREFIX out
  neighbor 192.168.100.1 route-map OUR-PREFIX-ROUTEMAP out
  no auto-summary
  no synchronization
  network 10.0.0.0
exit-address-family
ip forward-protocol nd
ip route 10.0.0.0 255.255.255.0 Null0
no ip http server
no ip http secure-server
Craft_Saf#sh ip bgp neighbors 192.168.100.1 advertised-routes
BGP table version is 7, local router ID is 192.168.100.2
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
*> 10.0.0.0     0.0.0.0                  0         32768 i
Total number of prefixes 1
You input will be highly appreciated.
Denis
7 Replies 7
ajay chauhan
Level 7
Level 7
Do you mean not getting these options ?
(config-router-af)#network 10.0.0.0 mask ?
  A.B.C.D  Network mask
I have the options and I key in the commands but once i do show run it does not show and as you can see the network is advertised without a mask.
Thks & Regards
The network you are advertising via BGP, do you have this network as a valid route in your routing table? Also, are you
using the correct network mask?
Kindly have a look at the code snipet above i have included;
D
When using address families i've always done the following.
router bgp x
neighbor x.x.x.x remote-as ASN
network y.y.y.y mask z.z.z.z
address-family ipv4
neighbor x.x.x.x activate
What happens when you go to router bgp x and type network (network) mask (mask)
The Router accepts the commands but once you show runn the
network y.y.y.y part appeears but the mask bit is missing.
mlund
Level 7
Level 7
Can You please show us exactly how You are doing, what mask do You configure on the network command.
The default for bgp is classfull mask, so if You configure
network 10.0.0.0 or
network 10.0.0.0 mask 255.0.0.0
the result in the config
will be network 10.0.0.0 for both the above.
If You configure
network 10.0.0.0 mask 255.255.255.0
itwill show up like that.
/Mikael
