BGP path section
Chris Zhang
Community Member
Hi everyone,
In the attached digram R4 in AS 30 seems to have two paths to 75.1.0.1/16 and 75.2.0.1/16 (on R7), one is through R6 and the other one is through R2 -> R1 -> R3 -> R5.
But the following on R4 only shows there is one path? I am expecting two paths to be shown but the best path being what is shown? Any ideas?
R4#sh ip bgp
     Network          Next Hop            Metric LocPrf Weight Path
 *>  75.1.0.0/16      46.0.0.6                 0             0 40 50 ?
 *>  75.2.0.0/16      46.0.0.6                 0             0 40 50 ?
 *>  125.1.0.0/16     46.0.0.6                 0             0 40 i
 *>  125.2.0.0/16     46.0.0.6                 0             0 40 i
Thanks!
Chris
10 Replies 10
Juan Ibañez
Level 3
Level 3
Hi ,
Please attach the configuration of all router in the topology.
Best Regards
Juan Ibañez
Thanks Juan,
Please see below.
R1:
interface FastEthernet0/0
 ip address 12.0.0.1 255.255.255.0
 speed auto
 duplex auto
interface FastEthernet0/1
 ip address 13.0.0.1 255.255.255.0
 speed auto
 duplex auto
router bgp 10
 bgp log-neighbor-changes
 neighbor 12.0.0.2 remote-as 10
 neighbor 13.0.0.3 remote-as 10
R2:
 ip address 12.0.0.2 255.255.255.0
 speed auto
 duplex auto
 ip address 24.0.0.2 255.255.255.0
 speed auto
 duplex auto
router bgp 10
 neighbor 12.0.0.1 remote-as 10
 neighbor 12.0.0.1 next-hop-self
 neighbor 24.0.0.4 remote-as 30
R3:
 ip address 13.0.0.3 255.255.255.0
 speed auto
 duplex auto
 ip address 35.0.0.3 255.255.255.0
 speed auto
 duplex auto
router bgp 10
 neighbor 13.0.0.1 remote-as 10
 neighbor 13.0.0.1 next-hop-self
 neighbor 35.0.0.5 remote-as 20
R4:
 ip address 24.0.0.4 255.255.255.0
 speed auto
 duplex auto
 ip address 46.0.0.4 255.255.255.0
 speed auto
 duplex auto
router bgp 30
 neighbor 24.0.0.2 remote-as 10
 neighbor 46.0.0.6 remote-as 40
R5:
 ip address 57.0.0.5 255.255.255.0
 speed auto
 duplex auto
 ip address 35.0.0.5 255.255.255.0
 speed auto
 duplex auto
router bgp 20
 neighbor 35.0.0.3 remote-as 10
 neighbor 57.0.0.7 remote-as 50
R6:
interface Loopback10
 ip address 125.1.0.1 255.255.0.0
interface Loopback20
 ip address 125.2.0.1 255.255.0.0
 ip address 46.0.0.6 255.255.255.0
 speed auto
 duplex auto
 ip address 67.0.0.6 255.255.255.0
 speed auto
 duplex auto
router bgp 40
 network 125.1.0.0 mask 255.255.0.0
 network 125.2.0.0 mask 255.255.0.0
 neighbor 46.0.0.4 remote-as 30
 neighbor 67.0.0.7 remote-as 50
R7:
 ip address 75.1.0.1 255.255.0.0
 ip address 75.2.0.1 255.255.0.0
 ip address 67.0.0.7 255.255.255.0
 speed auto
 duplex auto
 ip address 57.0.0.7 255.255.255.0
 speed auto
 duplex auto
router bgp 50
 redistribute connected route-map rmr7
 neighbor 57.0.0.5 remote-as 20
 neighbor 67.0.0.6 remote-as 40
ip forward-protocol nd
no ip http server
no ip http secure-server
access-list 10 permit 75.1.0.0 0.0.255.255
access-list 10 permit 75.2.0.0 0.0.255.255
route-map rmr7 permit 10
 match ip address 10
Hi Chris Zhang,
Where do you see that R4 have two paths to 75.1.0.1/16 and 75.2.0.1/16 (on R7), one is through R6 and the other one is through R2 -> R1 -> R3 -> R5??
Because BGP choose path with less AS-hop, in this case:
To R6 have two AS-hop >> AS40,AS50
To R2  have three AS-hop >> AS10,AS20, AS50
Regards!
Juan Ibañez
Thanks Juan. I don't see R4 having two alternative paths, which is why I was asking.
I know the best routes but 'sh ip bpg' should contain all possible paths?
Carlos Villagran
Hi!
Is R2 learning the routes via R3?
Regards!
JC
R2 does not peer with R3, it is only learning routes from R1 and R4.
Hi!
I presume that R2 is not learning 75.1.0.0/16 nor 75.2.0.0/16 routes? If that is the case, R4 will never learn those routes via R2 thus will not be showed in the show ip bgp table as next-hop.
Regards!
JC
The following is shown on R2 and R4:
R2#sh ip bgp
 *>  75.1.0.0/16      24.0.0.4                               0 30 40 50 ?
 *>  75.2.0.0/16      24.0.0.4                               0 30 40 50 ?
 *>  125.1.0.0/16     24.0.0.4                               0 30 40 i
 *>  125.2.0.0/16     24.0.0.4                               0 30 40 i
R4#sh ip bgp
 *>  75.1.0.0/16      46.0.0.6                               0 40 50 ?
 *>  75.2.0.0/16      46.0.0.6                               0 40 50 ?
R2 appears to be learning 75.x routes but it learnt from R4.
Do you know why R2 didn't learn alternative path to 75.x networks through R1 and go anti-clockwise to R3->R5-R7?
Hi!
Yes, this happens because R2 does not seem to be peering with R1 or with R3 so R2 is NOT learning routes from those neighbors and therefore does not know any other path for reaching 75.1.0.0/16 other than through R4.
If you want it to have the other path learned via BGP then you will have to peer it with R3. Anyway, the path through R6 will still be the preferred one since the AS_Path is shorter.
Hope it helps, best regards!
JC
Thanks Again Carlos!
R1 does appear to be peering with R2.
R2#sh ip bgp summary
Neighbor        V           AS MsgRcvd MsgSent   TblVer  InQ OutQ Up/Down  State/PfxRcd
12.0.0.1        4           10     535     563       15    0    0 07:28:37        0
24.0.0.4        4           30     587     574       15    0    0 08:20:43        4
But it didn't have any prefixes from R1 (12.0.0.1). Is this expected?
Below shows that R1 is peering with R2 (12.0.0.2) and R3 (13.0.0.3) and learnt four prefixes from each.
R1#sh ip bgp summary
12.0.0.2        4           10     565     537       55    0    0 07:32:07        4
13.0.0.3        4           10     529     524       55    0    0 07:32:07        4
Is it not expected for R1 to forward routes learnt from R3 (75.x) to R2?
