BGP scenario Problem:- Network prefixes should learn from both routers
Naive
Hello Team,
One interview question, There are 4 routers- R1, R2, R3 and R4 Connected as per below diagram
  1. Questions:- How 1.1.1.1 network reached to R3 and need to make sure 1.1.1.1 network reached through R4 if R3 will get down.[As a backup path]
  2. How 2.2.2.2 network reached to R4 and need to make sure 2.2.2.2 network reached through R3 if R4 will get down.[As a backup path]
We need to use BGP attribute
Hello
As stated if left to default then you would accomplish failover as it is. However if you wish to apply say as-path prepending from ASN 100 towards ASN200 then below should be applicable.
Example1
router 1
access-list 1 permit host 2.2.2.2
route-map AS-path permit 10
match ip address 1
set as-path prepend 100 100 100
route-map AS-path permit 99
router bgp 100
neighbour 3.3.3.3 route-map As-path out
router 2
access-list 1 permit host 1.1.1.1
match ip address 1
router bgp 100
neighbour 4.4.4.4 route-map As-path out
Example2
As for ASN200 - ASN100  then below should be applicable using local-preference.
router 3
route-map Local-Pref permit 10
match ip address 1
local-preference 110
route-map Local-Pref permit 99
router bgp 100
neighbour 1.1.1.1 route-map Local-Pref in
router 4
match ip address 1
router bgp 100
neighbour 2.2.2.2 route-map Local-Pref in
Kind Regards
Paul
5 Replies 5
Jon Marshall
Question doesn't really make sense.
For R1 to be able to use R2 as a backup path then they must be exchanging routes between themselves and presumably these are IBGP routes with an AD of 200.
So R1 will use the routes from R3 (EBGP - AD 20) unless the link goes down then it will use R2 (AD 200) so you don't need to use any BGP attribute.
If however you wanted R1 to use R2 as the main path and only use R3 as the backup path then you would use the local preference attribute to achieve that.
Jon
Hello John,
Thank you for your reply. Just want to clarify regarding below point.
  • Instead of LP we can't use weight as it is local specific, will not travel to ibgp peer. Right ?
  • I believe we need to apply LP on Ibgp neighbor from R1 towards R2, do we require to do some other configuration. i believe we also require next-hop-self between R4 to R3. Just trying to understand complete flow from R1-R2-R4-R3 for 1.1.1.1 N/w?
Hello
All things being equal (default)
R3 will reach 1.1.1.1  via R1
R4 will reach 2.2.2.2  via R2
If either R1-R2 fail reachability would go via the alternative rtr that is directly connected
However you can manipulate the default by as-path/local preference attributes
Kind Regards
Paul
Hello Paul,
Thank you for your reply, Could you please help to understand how we can apply Local preference/AS path attributes as per this scenario..
Hello
Example1
router 1
match ip address 1
router bgp 100
router 2
match ip address 1
router bgp 100
Example2
router 3
match ip address 1
router bgp 100
router 4
match ip address 1
router bgp 100
Kind Regards
Paul
