BGP Switch Recommendation
yamat5
Community Member
Looking for recommendation:
For our backend production systems we currently have a pair of Cisco WS-C3750X-48T-E distribution L3 switches with links to various layer 2 Top of Rack (TOR) Cisco WS-C3750X-48T-S switches. All using 1Gbps links
We want to:
Connect our two facilities with a pair of BGP enabled 10G links
Replace our current pair of Cisco WS-C3750X-48T-E backend distribution routers with a model that can support 10Gbps links. We want to use this replacement model as the distribution routers in building 2.
Any recommendation would be appreciated.
Mark Elsen
            - FYI : https://www.cisco.com/c/en/us/products/routers/router-selector.html
  M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
M02@rt37
Hello @yamat5,
Since you need basic routing, check C9300 series.
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9300-series-switches/nb-06-cat9300-ser-data-sheet-cte-en.html#Platformbenefits
You can stack them, basic BGP configuration, adapte your model with up to 10G uplinks with NM modules.
Best regards
