Policy routing with GRE tunnel
bclough
I need to be able to implement policy routing on traffic as it exits a GRE tunnel interface. However, policy routing is applied as traffic enters the interface, I need to know when the policy routing is tested and how it is applied.
The possibilities I can imagine are:
1. The policy is applied while the packet is still GRE encapsulated, and the routes are applied based on the GRE addresses, which are stripped off and discarded.
2. The policy is applied while the packet is still GRE encapsulated, and the routes are applied based on the GRE addresses, but the policy gets applied to the internal packet after the GRE header is removed.
3. The GRE header is removed and then the policy is applied.
4. You can't policy route the internal traffic.
brispin
Policy-based routing provides a tool for forwarding and routing data packets based on policies. In effect, it is a way to have the policy override routing protocol decisions. Policy-based routing includes a mechanism for selectively applying policies based on access list, packet size or other criteria. The actions taken can include routing packets on user-defined routes, setting the precedence, type of service bits, etc.
check out the following links for more information :
http://www.cisco.com/en/US/products/ps6599/products_white_paper09186a00800a4409.shtml
http://www.cisco.com/en/US/tech/tk543/tk545/technologies_tech_note09186a008017405e.shtml
m-haddad
Level 5
Level 5
If you apply the PBR on the incomming interface the traffic will be routed before being sent to the outgoing interface (GRE tunnel in your case).
In order to policy route the router's generated traffic you have to use the command
ip local-policy "policyname"
As for other traffic, try to match traffic using an ACL and then create a route-map for this ACL and policy base the traffic.
Try to police traffic as they arrive to the router i.e on the incomming interface of the router.
Hope my explanation did help,
Please rate if I was helpful,
The problem I have is NOT implementing policy routing on an outgoing GRE tunnel.
Instead, I need to policy route traffic when the incoming interface on the router is the GRE tunnel and the incoming traffic is encapsulated in the GRE header.
I need to make policy decisions based on the original IP header which is hidden by the GRE tunnel.
--Bruce
@bclough Did you find any answers?
