BGP with Port Channel on Nexus 3k switch
navkatu1
\Hi Team,
Is there a method to add an additional 10G link to an in-production 10 gig link to form a port channel.
Nexus 3K switch is having BGP with one of the router over L3 port. We are advertising and receiving the routes via with EBGP.
Now we almost exhaust the 10G link so we need to add one more 10G link with port-channel configuration.
Note : One of Nexus 3k 40G port is converted into 4*10G ports and for current setup we want to use Eth 1/49/2 for new 10G link. Can we configure port channel between eth 1/49/1 & 1/49/2 (10G Converted ports).
Current Config :
Nexus 3K :
interface Ethernet1/49/1
description ~Connected to Router A
no switchport
speed 10000
duplex full
ip address 10.254.0.30/30
no shutdown
router bgp 64997
router-id x.x.x.x
log-neighbor-changes
address-family ipv4 unicast
neighbor 10.254.0.29 remote-as 100
route-map from-lon04-peer-a out
Proposed Config :
description ~Port-channel1
no shutdown
Speed 10000
channel-group 1 mode active
interface Ethernet1/49/2
no shutdown
Speed 10000
Interface Port-channel 1
no  switch port
no shut
router bgp 64997
router-id x.x.x.x
Can anyone suggest will it work ?
Thanks in advance
balaji.bandi
is this vPC ?
i do not see any issue, but when you move from standalone port to ethernet channle Layer 3, you will have link convergency, that time you have BGP flap and reconvegence take place.
BB
Hi Balaji,
Thanks for the reply
It is not in VPC.
we will take complete downtime and perform the activity .
Sure that is agreed approach. let us know the outcome.
BB
