BGP
pankaj11189
How Configure BGP with NAT?
Boyan Sotirov
You cannot.
BGP is a routing protocol, NAT is a local function on a router. Both are separate functions from the router's perspective. So if you need to run BGP - you run it, if you need to configure NAT - you just go ahead and configure it.
Hi Boyan Sotirov
Thanks a lot.
