09-05-2011 11:10 PM - edited 03-07-2019 02:03 AM
I have an IBM Blade Center with 4 WS-CBS3012-IBM-I installed and i'm not able to have a response from the managemente interface (Fastethernet 0) when i try to connect to it from the managenent interface of the Blade Center, they don't respond to ping.
I've been checking the configuration and i can't find what can be missing.
Any ideas??
Thanks in advance.
Alfonso
09-05-2011 11:30 PM
Check whether you hit this bug: http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtg14607
If not, you probably need to provide more info including log, symptom, version, config
09-05-2011 11:46 PM
Hi Dazhi,
Here i attach the sh ver a sh run of the device, it has the latest version.
Do you think a downgrade can help?
