05-27-2009 01:40 AM - edited 03-06-2019 05:56 AM
Dear All,
How can i block a single IP with in a VLAN. this ip should not be able to access any other ips in the same vlan as well as other vlan in the network.
i have cisco WS-C3560G-48TS switch with me. please help me to do the same
05-27-2009 02:16 AM
I think you can create an inbound access-list and apply it to the vlan.
access-list 101 deny ip host
access-list 101 permit ip any any
I am assumming that you are using the switch as an L3 switch
05-27-2009 02:40 AM
Try looking into the Private VLAN feature.
The ACL method mentioned will not block trafic within the same VLAN.
HTH.
05-27-2009 02:43 AM
U need to use vlan-maps to achieve it.
Mahmood
05-27-2009 03:00 AM
As Ingolf mentionned, you need PVLAN to tale care of L2 blocking combined with an ACL for L3 blocking.
Sam
