Block DHCP traffic - DHCP Snooping
Machi Ma
If someone connecting into the switch and spoofing as a DHCP server.  Is it I just using DHCP Snooping to block those traffic like following?
Switch(config)#interface fastEthernet 0/4
Switch(config-if)#no ip dhcp snooping trust
#show ip dhcp snooping
Switch DHCP snooping is disabled
DHCP snooping is configured on following VLANs:
none
Insertion of option 82 is enabled
Option 82 on untrusted port is not allowed
Verification of hwaddr field is enabled
Interface Trusted Rate limit (pps)
FastEthernet0/4 no unlimited
Thanks!
sarathpa
First you need to enable DHCP snooping globally (You have not enabled). Then you need to make the interface as "Trust" when the original DHCP server connected. All other interface will be considered as "Untrust". So DHCP offer packet is allowed only in "Trust" interface. If  any DHCP packet received in "Untrust" interface will be dropped.
(config)#ip dhcp snooping
Thanks! How about if block under DHCPv6?  Is it like following?
# config t
# ipv6 dhcp guard policy dhcpv6-guard
# device-role server
# interface fa0/1-16
# ipv6 dhcp guard attach-policy dhcpv6-guard
# end
With some material it can create some access-list and prefix-list to allow which member of DHCP server is allow.  But in my case it just want to block all, so it did not edit those two list.
Thanks!
