Block L2 Hubs
Alex Li
Hello All,
I have a need to block users from connecting L2 hubs into my network, I am using Cisco L3 3850.
Is it more effective to use stp port fast or pbdu ?
Cheers
To deny users to connect hub to your switch port, the best and simplest way is port-security feature.
Portfast is not related to your problem.
BPDU guard is good but if they disable STP on their hub, it becomes useless.
Rgrds
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
To expand a bit on Houtan's suggestion, if your restrict your edge ports to only allowing one MAC, it will negate the advantage of connecting a "simple" hub or switch to the port.  However, if the connected device supports NAT, then you might restrict the edge port to a single known MAC (which will negate lots of NAT devices, but not if it supports setting its MAC).
