09-25-2013 01:21 AM - edited 03-07-2019 03:40 PM
Hello everyone,
I have 3 VLANs on the same interface and would like to block all the trafic between the VLAN 3 (Wifi access) and the two others ones VLAN 1 & 2 for security reason.
As the routing is automatic between the VLANS on the same interface, how can I block the trafic? Do I need to use access-list ?
Thanks for your help!
Here is an extract of my configuration :
interface GigabitEthernet0/0
description Fiber Swisscomm
no ip address
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
no mop enabled
interface GigabitEthernet0/1
description LAN-Greenwich
no ip address
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1.1
description LAN Greenwich
encapsulation dot1Q 1 native
ip address 192.168.0.254 255.255.255.0
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1452
interface GigabitEthernet0/1.2
description IPC
encapsulation dot1Q 2
ip address 192.168.1.254 255.255.255.0
interface GigabitEthernet0/1.3
description Wifi Greenwich
encapsulation dot1Q 3
ip address 192.168.2.254 255.255.255.0
ip nat inside
Solved! Go to Solution.
09-25-2013 01:34 AM
Yes, you would need an access list. something like this
ip access-list extended RESTRICT_WIFI
deny ip any 192.168.0.0 0.0.0.255
deny ip any 192.168.1.0 0.0.0.255
permit ip any any
ip access-group RESTRICT_WIFI in
http://www.rConfig.com
A free, open source network device configuration management tool, customizable to your needs!
- Always vote on an answer if you found it helpful
09-25-2013 01:34 AM
permit ip any any
09-25-2013 02:34 AM
Thanks for your reply!
