block wifi guest vlan from accessing other vlans resources
amralrazzaz
Level 5
Level 5
need to block network traffic from vlan wifi guest to other vlans resources like (lan/wifi office/printer/mgmt/server/cctv and so on)
so wifi guest vlan can access intetnet only
vlan wifi guest cannot access  other vlans but vise versa is ok ... ( am i right ? or what the standrad for that) >?
here u are the following vlans i have :
LIST OF INTERVLAN ROUTING G.W:
VLAN 2 192.168.2.207/24VLAN 2 LAN
192.168.3.207/24VLAN 9 PRINTER
192.168.4.207/24VLAN 20 WIFI-OFFICE
192.168.5.207/24VLAN 55 NATIVE
192.168.6.207/24VLAN200 VOICE
192.168.7.207/24VLAN250 MGMT
192.168.8.207/24VLAN912 WIFI-GUEST
192.168.9.207/24 VLAN230 STREAMING
ip dhcp pool LAN
network 192.168.2.0 255.255.255.0
default-router 192.168.2.207
dns-server 8.8.8.8
ip dhcp pool Printers
network 192.168.3.0 255.255.255.0
default-router 192.168.3.207
dns-server 8.8.8.8
ip dhcp pool WIFI-OFFICE
network 192.168.4.0 255.255.255.0
default-router 192.168.4.207
dns-server 8.8.8.8
ip dhcp pool Native
network 192.168.5.0 255.255.255.0
default-router 192.168.5.207
dns-server 8.8.8.8
ip dhcp pool Voice
network 192.168.6.0 255.255.255.0
default-router 192.168.6.207
dns-server 8.8.8.8
ip dhcp pool MGMT
network 192.168.7.0 255.255.255.0
default-router 192.168.7.207
dns-server 8.8.8.8
ip dhcp pool WIFI-GUEST
network 192.168.8.0 255.255.255.0
default-router 192.168.8.207
dns-server 8.8.8.8
ip dhcp pool STREAMING
network 192.168.9.0 255.255.255.0
default-router 192.168.9.207
dns-server 8.8.8.8
ip cef
no ipv6 cef
spanning-tree mode pvst
interface FastEthernet0/0
description connected to local NW-INTERVLAN
no ip address
ip nat inside
duplex auto
speed auto
interface FastEthernet0/0.2
description LAN
encapsulation dot1Q 2
ip address 192.168.2.207 255.255.255.0
ip nat inside
interface FastEthernet0/0.9
description printers
encapsulation dot1Q 9
ip address 192.168.3.207 255.255.255.0
ip nat inside
interface FastEthernet0/0.20
description WIFI-OFFICE
encapsulation dot1Q 20
ip address 192.168.4.207 255.255.255.0
ip nat inside
interface FastEthernet0/0.55
description native
encapsulation dot1Q 55 native
ip address 192.168.5.207 255.255.255.0
ip nat inside
interface FastEthernet0/0.200
description voice
encapsulation dot1Q 200
ip address 192.168.6.207 255.255.255.0
ip nat inside
interface FastEthernet0/0.230
description streaming
encapsulation dot1Q 230
ip address 192.168.9.207 255.255.255.0
ip nat inside
interface FastEthernet0/0.250
description WIFI-GUEST
encapsulation dot1Q 250
ip address 192.168.7.207 255.255.255.0
ip access-group 101 in
ip access-group 101 out
ip nat inside
interface FastEthernet0/0.912
encapsulation dot1Q 912
ip address 192.168.8.207 255.255.255.0
ip nat inside
interface FastEthernet0/1
description connedted to ISP
ip address 192.168.1.207 255.255.255.0
ip nat outside
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
Frico(config-subif)#interface FastEthernet0/0.250
Frico(config-subif)# encapsulation dot1Q 250
Frico(config-subif)# ip address 192.168.7.207 255.255.255.0
Frico(config-subif)# ip nat inside
Frico(config-subif)#description WIFI-GUEST
Frico(config-subif)#no ip access-group 101 OUT
Frico(config-subif)#no ip access-group 101 in
Frico(config-subif)#do wr
Building configuration...
[OK]
Frico con0 is now available
Press RETURN to get started.
User Access Verification
Password:
Password:
Password:
r>en
Password:
Password:
r#show run
Current configuration : 4477 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Frico
enable password cisco
ip dhcp excluded-address 192.168.2.207
ip dhcp excluded-address 192.168.3.207
ip dhcp excluded-address 192.168.4.207
ip dhcp excluded-address 192.168.5.207
ip dhcp excluded-address 192.168.6.207
ip dhcp excluded-address 192.168.7.207
ip dhcp excluded-address 192.168.8.207
ip dhcp excluded-address 192.168.9.207
ip dhcp excluded-address 192.168.7.1
ip dhcp excluded-address 192.168.7.10
ip dhcp excluded-address 192.168.3.88
ip dhcp excluded-address 192.168.2.10
ip dhcp excluded-address 192.168.2.100
ip dhcp pool LAN
dns-server 8.8.8.8
dns-server 8.8.8.8
dns-server 8.8.8.8
ip dhcp pool Native
dns-server 8.8.8.8
ip dhcp pool Voice
dns-server 8.8.8.8
ip dhcp pool MGMT
dns-server 8.8.8.8
dns-server 8.8.8.8
dns-server 8.8.8.8
ip cef
no ipv6 cef
no ip address
ip nat inside
duplex auto
speed auto
description LAN
ip nat inside
ip nat inside
ip nat inside
description native
ip nat inside
description voice
ip nat inside
ip nat inside
ip nat inside
ip nat inside
ip nat outside
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
router eigrp 100
network 192.168.1.0
network 192.168.2.0
network 192.168.3.0
network 192.168.4.0
network 192.168.5.0
network 192.168.6.0
network 192.168.7.0
network 192.168.8.0
no auto-summary
ip nat inside source list 1 interface FastEthernet0/1 overload
ip nat inside source list 2 interface FastEthernet0/1 overload
ip nat inside source list 3 interface FastEthernet0/1 overload
ip nat inside source list 4 interface FastEthernet0/1 overload
ip nat inside source list 5 interface FastEthernet0/1 overload
ip nat inside source list 6 interface FastEthernet0/1 overload
ip nat inside source list 7 interface FastEthernet0/1 overload
ip nat inside source list 8 interface FastEthernet0/1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.253
ip flow-export version 9
access-list 1 permit 192.168.2.0 0.0.0.255
access-list 2 permit 192.168.3.0 0.0.0.255
access-list 3 permit 192.168.4.0 0.0.0.255
access-list 4 permit 192.168.5.0 0.0.0.255
access-list 5 permit 192.168.6.0 0.0.0.255
access-list 6 permit 192.168.7.0 0.0.0.255
access-list 7 permit 192.168.8.0 0.0.0.255
access-list 8 permit 192.168.9.0 0.0.0.255
no cdp run
line con 0
password cisco
login
line aux 0
line vty 0 4
password
login
end
amr alrazzaz
17 Replies 17
Dennis Mink
Usually the way this is done is by means of a guest wifi vlan that you terminate into a dmz. Or even a dedicated internet router. So therr is bo layer 3 cross over with it in your network
Please remember to rate useful posts, by clicking on the stars below.
thanks a lot
can u please help and give me example how to block access from guest to other internal resources and allow only internet access by using access list ???
whats dmz ?
amr alrazzaz
the below should work. Networks 192.168.2.0/24 thru 192.168.7.0/24 are summarized as 192.168.0.0/21.
access-list 111 deny ip 192.168.0.0 0.0.7.255 192.168.8.0 0.0.0.255
access-list 111 deny ip 192.168.8.0 0.0.0.255 192.168.0.0 0.0.7.255
access-list 111 deny ip 192.168.8.0 0.0.0.255 192.168.9.0 0.0.0.255
access-list 111 deny ip 192.168.9.0 0.0.0.255 192.168.8.0 0.0.0.255
access-list 111 permit ip any any
ip access-group 111 in
ip nat inside
as per ur configuration the below so i can under stand the following and please correct me and whats the standards for that in companies? :
1- wifi guest cannot connect or even ping on any of the other vlans ?
2- other vlans can connect to wifi guest as well or not ? so the connection in both direction block ?
3- what if i need to allow only the printer vlan to wifi guest vlan ?
4- the summarize vlans ip is from 2 to 7 only ? correct ? not including 8 and 9 networks?
thanks a lot
amr alrazzaz
the access list blocks access from the guest Vlan to all other Vlans, and vice versa. The guest Vlan can only access the Internet and nothing else.
If you need a printer to be able to access Vlan 8, you need to add a host entry:
access-list 111 permit ip host x.x.x.x any
access-list 111 permit ip any host x.x.x.x
where x.x.x.x is the IP address of your printer.
192.168.8.0/24 IS the wife guest network, right ? Addresses 2-7 are summarized, the entry for 9 is at the end of the access list.
dear as below acl wifi guest vlan cant reach any other vlans and also vlan 8 (wifi guest ) still cant access the 2 printers that i have on network ( vlan 9) as below :
access-list 111 permit ip host 192.168.3.3 any
access-list 111 permit ip any host 192.168.3.3
access-list 111 permit ip host 192.168.3.1 any
access-list 111 permit ip any host 192.168.3.1
so still cant wifi guest connect to printer ?:)
amr alrazzaz
you need to change the order of the access list. Entries are processed in sequence, so your host entries need to be first. Remove the access list, and then add it again, in the order below:
thanks a lot dear
another q:
on the wifi guest as below  so is it okay ? for the ip access group 111 in and what if i add out also in addition
and for the ip nat inside is to the internet access ? am i correct ?
ip nat inside
amr alrazzaz
you only need to apply the access list inbound. NAT is not affected, as you allow all traffic from the guest Wifi Vlan to the Internet...
is this on is okay ???
i have two printer 192.168.3.1 and 3.2 so if i need only to provide guest wifi an access to only these 2 printer only same as below is okay ?or should i make any changes ?
ip access-list extended in_guest_traffic
permit ip host 192.168.3.2 any
permit ip any host 192.168.3.2
deny ip any 192.168.2.0 0.0.0.255
deny ip any 192.168.3.0 0.0.0.255
deny ip any 192.168.4.0 0.0.0.255
deny ip any 192.168.5.0 0.0.0.255
deny ip any 192.168.6.0 0.0.0.255
deny ip any 192.168.7.0 0.0.0.255
deny ip any 192.168.9.0 0.0.0.255
permit ip any any
#apply it to the interface
ip access-group in_guest_traffic in
end
amr alrazzaz
apply the below and see what the result is:
ip nat inside
Havr you got a firewall at all in your network?
i have 1 cisco router isr 2911 - 2 of SWITCH 24 PORTS CATALYST 2960 - X SERIES
and please find attached pic of the network design maybe its more clear to understand
thanks
amr alrazzaz
Hello
Your listing of vlan250 shows its MGT vlan on sub-interface fa0/0.250, I assume this is a typo in your configuration and if so you access-list is applied to the wrong sub-interface?
Also the current defined acl 101 is summarized to also include your printer vlan which would be incorrect.
So to allow communication between Vlan 9 Printer & Vlan 912 wifi guest , deny all other communication to wifi guest vlan.
Could you try the following:
conf t
int fa0/0.250
no ip access-group 101 out
exit
no access-list 101
access-list 100 remark allow Wifi-Guest to Printer vlan and internet
access-list 100 deny ip any 192.168.2.0 0.0.0.255
access-list 100 deny ip any 192.168.4.0 0.0.0.255
access-list 100 deny ip any 192.168.5.0 0.0.0.255
access-list 100 deny ip any 192.168.6.0 0.0.0.255
access-list 100 deny ip any 192.168.7.0 0.0.0.255
access-list 100 deny ip any 192.168.9.0 0.0.0.255
access-list 100 permit ip any any
access-list 101 remark allow Printer vlan to Wifi-Guest
access-list 101 deny ip 192.168.2.0 0.0.0.255 any
access-list 101 deny ip 192.168.4.0 0.0.0.255 any
access-list 101 deny ip 192.168.5.0 0.0.0.255 any
access-list 101 deny ip 192.168.6.0 0.0.0.255 any
access-list 101 deny ip 192.168.7.0 0.0.0.255 any
access-list 101 deny ip 192.168.9.0 0.0.0.255 any
access-list 101 permit ip any any
int fa0/0.912
ip access-group 100 out
Kind Regards
Paul
