Blocking from going to ROMMON
omal
Level 6
Level 6
Can we block a router from going to rommon mode, when we break the booting process?
There is a 2600 series router, when I turn off and turn it back on, I press Ctrl + Break commands. Then I get the below posted screen.
I cannot break the password. Can someone do something to the configuration, where I cannot go in to ROMMON> mode.
Any help on this would be highly appreciated.
The output of the router I will paste it in two posts as I exceed the words liminit when I try to post it in one.
Thanks in advance!!!
Press RETURN to get started!
System Bootstrap, Version 12.1(3r)T2, RELEASE SOFTWARE (fc1)
Copyright (c) 2000 by cisco Systems, Inc.
PC = 0xfff0c100, Vector = 0x500, SP = 0x680127d0
PC = 0xfff08050, Vector = 0x500, SP = 0x680127c0
C2600 platform with 49152 Kbytes of main memory
PASSWORD RECOVERY FUNCTIONALITY IS DISABLED
PC = 0xfff115f8, Vector = 0x500, SP = 0x800046ac
program load complete, entry point: 0x80008000, size: 0xa14d18
Self decompressing the image : #################################################
############ [OK]
Smart Init is enabled
smart init is sizing iomem
ID MEMORY_REQ TYPE
0001C0 0X0010A400 C2600 Dual Fast Ethernet
0X000F34A8 public buffer pools
0X00211000 public particle pools
TOTAL: 0X0040E8A8
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Rounded IOMEM up to: 5Mb.
Using 10 percent iomem. [5Mb/48Mb]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
smothuku
Level 11
Level 11
Hi Omal ,
Recovery Mechanism:
If a user uses the secure ROMMON and loses the enable password, there is a way to erase the entire contents of NVRAM:
1.Boot the system
2.Wait until after the system decompresses the IOS image:
Self decompressing the image : ################################################]
3.Hit break within five seconds.
4.The 3600 will ask if you want to reset the router to the factory default configuration:
PASSWORD RECOVERY IS DISABLED.
Do you want to reset the router to factory default
configuration and proceed [y/n] ? y
Reset router configuration to factory default.
Risks:
If a router is configured with no service password-recovery, this disables all access to the ROMMON.
If there is not a valid IOS image in flash in the router, then the user will not be able to use the ROMMON XMODEM command to load a new flash image. In order to fix the router, you must get a new IOS image on a flash SIMM, or on a PCMCIA card (3600 only). In order to minimize this risk, a customer who uses ROMMON security should also use dual flash bank memory and put a backup IOS image in a separate partition. On the 3640 only, in an emergency you can remove the NVRAM and reseat it. The 3640 NVRAM is implemented using battery backed up SRAM. Removing the SRAM will erase the contents of NVRAM, which contains the no service password-recovery configuration. The NVRAM chip is located on the motherboard of the 3640 next to the PCMCIA connector. The silkscreen on the motherboard will identify it as "NVRAM".
*****Please be sure to use proper anti-static procedures when handling the NVRAM. The 3620 and 2600 use an EEPROM to hold the configuration. The EEPROM does not erase when you remove it.
Since from the above procedure all data will be lost on the router! A backup config might be helpful in bringing back the old configuration.
I Hope this helps you!
Satish
9 Replies 9
omal
Level 6
Level 6
IOS (tm) C2600 Software (C2600-IS-M), Version 12.2(2)T, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/cgi-bin/ibld/view.pl?i=support
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Sat 02-Jun-01 21:34 by ccai
Image text-base: 0x80008088, data-base: 0x8118A888
cisco 2651 (MPC860P) processor (revision 0x200) with 44032K/5120K bytes of memor
y.
Processor board ID JAB05340FRP (4260492592)
M860P processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
2 FastEthernet/IEEE 802.3 interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
interface Serial0/0
% Invalid input detected at '^' marker.
no ip address
% Incomplete command.
encapsulation ppp
ppp multilink
multilink-group 1
interface Serial0/1
description Second_E1
no ip address
encapsulation ppp
ppp multilink
multilink-group 1
User Access Verification
Password:
Password:
Password:
% Bad passwords
omal
Level 6
Level 6
PDRouter_SW2 con0 is now available
Press RETURN to get started.
PC = 0xfff115f4, Vector = 0x500, SP = 0x800046ac
PC = 0xfff14f74, Vector = 0x500, SP = 0x80004884
PC = 0xfff14f70, Vector = 0x500, SP = 0x80004884
PC = 0xfff14f74, Vector = 0x500, SP = 0x80004394
PC = 0x800043d4, Vector = 0x500, SP = 0x800043bc
############ [OK]
ID MEMORY_REQ TYPE
TOTAL: 0X0040E8A8
cisco Systems, Inc.
omal
Level 6
Level 6
y.
Bridging software.
interface Serial0/0
no ip address
encapsulation ppp
ppp multilink
multilink-group 1
interface Serial0/1
no ip address
encapsulation ppp
ppp multilink
multilink-group 1
There is a service setting that does not allow for password recovery.
If it is set, and you lose / forget / don't know the password, it requires an RMA.
I don't know if that's the case here, but it's a possibility.
It might also be the case that your terminal emulation is not sending the right "break" character. Try ctrl-c, check your emulation settings, try a straight-up VT100, try ANSI, try whatever you have.
Try another emulator, try another PC/Laptop.
Good Luck
Scott
Hi Scott
Thanks a lot for your reply. Well you are right. That service setting was used. But after reseting a BIOS ic like thing, the password has got reset. It was someone else who did this. Therefore I'm not quite sure how has it really done.
Anyway thank you so much for taking time to give me a reply.
You can restrict password recover option by using "no service password-recovery", command.
rgds,
Thanks a lot for you advice. It's very helpful.
Best regards!!!!
smothuku
Level 11
Level 11
Hi Omal ,
Recovery Mechanism:
1.Boot the system
Risks:
Satish
Hi Satish
Thank you so much for your answer.
Really appreciate it.
Best regards
Omal
