Blocking multicast and unicast flooding on specific ports on Cisco 6509
bhushit17
I want to block unicast/multicast flooding on cisco 6509 (only L2 capabilities).
The packets destined for a mac not known to the switch are unicast/multicast flooded to all ports of the switch, but I have a couple of ports connected to critical servers which should not get these packets.
I tried blocking the multicast and unicast (switchport block multicast) but it does block ping from local network also.
switchport block unicast
How can I stop just that flooding of packet to these couple of ports ?
2 Accepted Solutions
Well done.  The other option is to create a new layer 3 subnet, and a new VLAN, and put the Microsoft NLB into that.  Then the flooding will be limited to only ports in that VLAN.
Hi Bhushit17,
Ok, if you have implemented NLB in Unicast Mode, it is recommended that you use a dedicated VLAN for NLB so that the flooding is constrained.
More explanation below :
Unicast Mode
  • In Unicast mode, NLB replaces the actual Media Access Control (MAC) address of each server in the cluster with a common NLB MAC address. When all of the servers in the cluster have the same MAC address, all of the packets that are forwarded to that address are sent to all of the members in the cluster. The NLB creates a fictitious MAC address and assigns it to each server in the NLB cluster. The NLB assigns each NLB server a different fictitious MAC address, based on the host ID of the member. This address appears in the Ethernet frame header.
  • The MAC address is used in the Address Resolution Protocol (ARP) header, not the Ethernet header. The switch uses the MAC address in the Ethernet header, not the ARP header. This causes an issue when a packet is sent to the NLB cluster with the destination MAC address as the cluster MAC address 00-bf-ac-10-00-01. The switch views the Content Addressable Memory (CAM) table for the MAC address 00-bf-ac-10-00-01, and since there is no port registered with the NLB cluster MAC address 00-bf-ac-10-00-01, the frame is delivered to all of the switch ports. This introduces unicast floodingIn order to avoid flooding, Cisco recommends that you use a dedicated VLAN for NLB so that the flooding is constrained.
Good read below :
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-series-switches/107995-configure-nlb-00.html
Hope this helps you !
Mark it useful if you feel so.
Cheers ! :)
8 Replies 8
Philip D'Ath
<snip> Oops, got that wrong.  I would have tried the approach you already have.
It should only block a "ping" to a host it has not yet seen.  As soon as the host "talks" it should work.
Yes it should, but this isn't happening unless I start the ping before putting the command:
I think arp resolution isn't possible after the command.
If switch has to re-learn the server mac,  it has to floods packets with unknown destination MAC addresses to all ports.. Having said that, if you block unicst/mcast flood to those ports, then it wont learn and put mac entry.
I would not advise you to go for blocking uncst/mcast flood pkts, unless you know there wont be any situation of mac ageing out.
Hope it helps !
Cheers ... :)
Hi Chsarkar,
Actually I have Microsoft Network Load Balancer connected to this same switch, and there is Multicast mac configured in that NLB, now since this is only an L2 switch, no mac has been learnt by this switch hence this flooding.
Now I am trying to configure static mac for this NLB on switch, hope it will solve my problem.
Cheers :)
Hi Bhushit17,
Unicast Mode
Good read below :
Cheers ! :)
Configuring static mac does the job for me:),  although I can put the NLB in different vlan, that option should however be more apt before NLB implementation.
