blocking multicast inside a vlan
CrackedJack1
Level 3
Level 3
Is it possible to block multicast inside a vlan?
I'm trying to create a vlan that doesn't allow multicast between devices within the vlan.
With multicast routing, I think I simply make sure there's no ip pim sparse/dense command in the vlan config and that will prevent any multicast from entering/leavng the vlan which solves half my problem.
For physical devices connected to a port on the vlan in question, I think there's a storm-control and 1 other command will block it all multicast to that port which I believe solves the multicast within the vlan but......
My problem is with virtual machines. While I can put them on the vlan, I don't have the cisco 1000 virtual switch to block each port.
Given that, is there any config which will prevent devices in the same vlan from using multicast without configuring a physical port?
I'm working with 3850 and 4500 switches in this case
5 Replies 5
cadet alain
You can use a VLAN access-list(VACL) to block some traffic inside a VLAN.
Alain
Are you able to give me an example? I know very little about ACL and my attempts have all failed.
I tried the following
ip access-list standard TEST
deny 224.0.0.0 15.255.255.255
permit any
int vlan 51
ip access-group TEST in
ip access-group TEST out
but it doesn't see to work. I remove the permit any but that doesn't make a different either. Is my ACL wrong?
a multicast address can never be seen as a source address but only as a destination address so  you must use an extended ACL not a standard ACL and put your multicast address as a destination:
access-list 100 permit ip 224.0.0.0  15.255.255.255
vlan access-map block-multicast 10
match ip address100
action drop
vlan access-map block-multicast 20
action forward
vlan-filter block-multicast  vlan-list x  where x is the vlan id
Alain
Hi Alain,
Thank you so much! It appears to be working. We'll see what happens in a few days when I reconfigure if it holds but so far so good
These are the final commands which did the trick if anyone else comes across this thread:
access-list 100 permit ip any 224.0.0.0 15.255.255.255
match ip address 100
action drop
action forward
vlan filter block-multicast vlan-list x (where x is the vlan id)
Using the same idea I was able to block UDP traffic as well in/out/within the vlan as well.
Is there a large performance impact to using these filters? I would be putting them on a 3850 so i would assume i have enough cpu but any guidance is appreciated.
Hello Alain, aren't we at risk of blocking service messages destined to all host or all routers with this access-list  that cojld interfer with functionning of the network ? Shouldn't we block 225.x.x.x upwards ?
