Boot variables on next reload does not change after boot system flash:
getaway51
Level 2
Level 2
May i know why after settings the boot system cmd, the Boot Variables on next reload not changing to c3750-ipbasek9-mz-122-55.SE1.bin? Isnt the Current Boot Variables is the "current ios" & Boot Variables on next reload:is "the next reload ios in boot system command"?
# config t
# boot system switch all flash:c3750-ipbasek9-mz-122-55.SE1.bin
sh boot system
Switch 1
Current Boot Variables:
c3750-ipbasek9-mz-120-10.SE1.bin
2 Accepted Solutions
yes save it first , then check the show boot again
Hello
Try deleting the boot var before applying new boot statement.
conf t
no boot system switch all
do show boot
boot system switch all flash:x.x.x.x.bin
Kind Regards
Paul
12 Replies 12
Mark Malone
did you save it , it should show after copy run start ?
do i need to save it? I didn't do write mem.
I havent reboot yet too.
Did you mean it will change after i do "write mem"?
If it is still playing up after saving the config, please share the output of sh ver
...it could be the configuration register value you have configured.
Cheers,
Seb.
if you did "wr mem" and still not worked, check this:
1. May be you have 3 or more .bin files on flash. (try leaving no more than two files)
2. Check your . bin file and may be download him again.
make sure its right before rebooting first
thank you Mark! just ran into this same issue.
Thanks it worked
Hello
conf t
do show boot
Kind Regards
Paul
after these 4 commands, do i need "write mem"?
Hello
yes you do.
Kind Regards
Paul
Leo Laohoo
Whao! I've never seen an old IOS such as that!
