booting after softreset
sohail-khan
my catalyst 2950 is resuming after give this message (booting after softreset )
can any one help me what to do .
spremkumar
Level 9
Level 9
can you paste the exact message you are seeing out there during booting ?
regds
thanks for reply below is the message i am geting & switch is booting , booting .....
Loading "flash:/c2950-i6q4l2-mz.121-22.EA7.bin"...##############################
File "flash:/c2950-i6q4l2-mz.121-22.EA7.bin" uncompressed and installed, entry p
oint: 0x80010000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(22)EA7, RELEASE SOFTWARE
(fc1)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Fri 27-Jan-06 21:19 by antonino
Image text-base: 0x80010000, data-base: 0x8056A000
Initializing flashfs...
flashfs[1]: 598 files, 5 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 7741440
flashfs[1]: Bytes used: 5101568
flashfs[1]: Bytes available: 2639872
flashfs[1]: flashfs fsck took 8 seconds.
flashfs[1]: Initialization complete.
Done initializing flashfs.
POST: System Board Test : Passed
The MAC Address has not been set in the environment.
Using default address: 04:04:04:00:00:01
POST: Ethernet Controller Test : Passed
ASIC Initialization Passed
POST: FRONT-END LOOPBACK TEST : Passedcisco WS-C2950-24 (RC32300) processor with
21004K bytes of memory.
Last reset from system-reset
Running Standard Image
24 FastEthernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Invalid parameter block -- no serial number or mac address available.
--- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]:
=== Flushing messages (00:00:19 UTC Mon Mar 1 1993) ===
Buffered messages:
Queued messages:
00:00:19: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging out
put.
00:00:16: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
00:00:17: %ENVIRONMENT-3-RPS_FAILED: Faulty internal power supply detected
Signal 10, Exception code (0x0008)!
Frame 00: SP = 0x80B90E80 PC = 0x802D2A90
Frame 01: SP = 0x80B90E98 PC = 0x802D30DC
Frame 02: SP = 0x80B90EB8 PC = 0x80191D48
Frame 03: SP = 0x80B90EE8 PC = 0x8034FFA0
Frame 04: SP = 0x80B90F00 PC = 0x803056CC
Frame 05: SP = 0x80B90F18 PC = 0x8011FD20
Frame 06: SP = 0x80B91028 PC = 0x801BC908
Frame 07: SP = 0x80B91040 PC = 0x801BC8F4
=== Crash Fault History ===
C2950 Software (C2950-I6Q4L2-M), Version 12.1(22)EA7, RELEASE SOFTWARE (fc1)
Signal = 10, Code = 0x8, Uptime 00:00:19
r0: 00000000, AT: 00000000, v0: 00000000, v1: 8066644C
a0: 00000030, a1: 000000FF, a2: 80660000, a3: 80C93CC0
t0: 00000018, t1: 1000E101, t2: 1000E100, t3: FFFF00FF
t4: 802D20B0, t5: A08C24A0, t6: 00000000, t7: A08C2498
s0: 00000000, s1: 80D12704, s2: 00000000, s3: 00000000
s4: 80865F90, s5: 80860000, s6: 80B90FF8, s7: 80850000
t8: A08C250C, t9: 00000000, k0: 00000000, k1: 00000000
gp: 807DED20, sp: 80B90E80, s8: 80870000, ra: 802D2A90
EPC: 802D2A90, ErrEPC: 02E98041, BadVA: 0x0000003C, SREG: 1000E103
Cause: 0x00000008 (code 2): TLB (load or ifetch) exception
-Traceback= 802D2A90 802D30DC 80191D48 8034FFA0 803056CC 8011FD20 801BC908 801BC
8F4
Booting after a softreset ...
Log says that "Internal Power Supply has gone faulty".
Let me know is there any RPS/External Power Supply is connected to this switch ??
Most probably, you will have to replace the switch.!!!
Sounds like the internal supply has failed and its running on a RPS like a rps 2300 .
