Booting problem on SUP720
dominic.caron
Level 11
Level 11
One of my 6500 is refusing to boot with it's new software image.
DKNCORA#sh boot
BOOT variable = disk0:s72033-advipservicesk9_wan-mz.122-18.SXF14.bin,12;sup-bootflash:s72033-ipservicesk9-mz.122-18.SXF10.bin,1;
CONFIG_FILE variable =
BOOTLDR variable =
I want to upgrade from SXF10 to SXF14.
here's the reload output
Jul 15 08:09:01: %SYS-SP-5-RELOAD: Reload requested
Jul 15 08:09:01: %OIR-SP-6-CONSOLE: Changing console ownership to switch processor
Jul 15 08:09:01: %SYS-SP-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
System Bo otstrap, Version 8.1(3)
Copyright (c) 19 94-20 04 by cisco Systems, Inc.
Cat6k-Sup720/SP processor with 524288 Kbytes of main memory
Autoboot executing command: "boot bootflash:"
Loading image, please wait ...
Self extracting the image... [OK]
Self decompressing the image : ##################################################################################################### [OK]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
IOS (tm) s72033_sp Software (s72033_sp-IPSERVICESK9-M), Version 12.2(18)SXF10, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Fri 13-Jul-07 08:39 by kellythw
Image text-base: 0x40101040, data-base: 0x41473450
Any idea ?
dominic.caron
Level 11
Level 11
Found it, need to upgrade rommon
dabrooks
Visitor
Did you resolve this problem. I'm getting exactly the same but when using a Supy 32. Also the switch will get to the same stage, i.e. Image text-base:
and then start over the RP loading sequence.
For the newer software, you should remove the boot statement "boot system flash sup-bootflash:xxxxx" if you are running Native IOS. This file system is on the MSFC and it is not going to be used to boot up the switch.
Boot image should be stored in sup-disk0: or sup-bootdisk:.
HTH,
jerry
