Bootstring invalid
saikchak1
Community Member
Hi Community,
I am getting this error in the log message now for a quite some time. This is cisco WS-C6509-E with
s72033-advipservicesk9_wan-vz.122-33.SXI8a.bin as the IOS image.
%PFREDUN-SP-4-BOOTSTRING_INVALID: The bootfile slavesup-bootdisk:s72033-advipservicesk9_wan-vz.122-33.SXI8a.bin is present on the active supervisor but not on the standby
The show bootvar is as follows
show bootvar
BOOT variable = sup-bootdisk:s72033-advipservicesk9_wan-vz.122-33.SXI8a.bin,1;slavesup-bootdisk:s72033-advipservicesk9_wan-vz.122-33.SXI8a.bin,1;
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
Standby is up
Standby has 1048576K/8192K bytes of memory.
Standby BOOT variable = sup-bootdisk:s72033-advipservicesk9_wan-vz.122-33.SXI8a.bin,1;slavesup-bootdisk:s72033-advipservicesk9_wan-vz.122-33.SXI8a.bin,1;
Standby CONFIG_FILE variable does not exist
Standby BOOTLDR variable does not exist
Standby Configuration register is 0x2102
dir sup-bootdisk:
Directory of sup-bootdisk:/
    1  -rw-    33554432  Jan 31 2012 08:53:56 +08:00  sea_console.dat
    2  -rw-   180274484  Jan 31 2012 09:00:04 +08:00  s72033-advipservicesk9_wan-vz.122-33.SXI8a.bin
dir slavesup-bootdisk:
Directory of slavesup-bootdisk:/
    1  -rw-   180274484  Jan 31 2012 08:50:14 +08:00  s72033-advipservicesk9_wan-vz.122-33.SXI8a.bin
    2  -rw-    33554432  Jan 31 2012 08:44:20 +08:00  sea_console.dat
As far I can see the IOS is present in both the locations, but still getting this error.
Best Regards
Saikat Chakraborty
5 Replies 5
Arumugam Muthaiah
Hi Saikat,
What is the boot sequence configured on this switch? could you share the #show run | i boot
Did you do any change recently on this switch. could you share the show log from the switch as well
Aru
*** Please rate if the post is useful ***
Regards, Aru *** Please rate if the post useful ***
As requested,
boot-start-marker
boot system flash sup-bootdisk:s72033-advipservicesk9_wan-vz.122-33.SXI8a.bin
boot system flash slavesup-bootdisk:s72033-advipservicesk9_wan-vz.122-33.SXI8a.bin
boot-end-marker
Attached are the logs. There are one more 6500-E which is also having the same problem. Also there are two 7600 switches which have  identical boot sequence and both have CISCO IOS images in there sup-bootdisk: and slavesup-bootdisk:.
In regards to any recent config change, it happened on 23rd Oct 2012 which involved integrating them to ASR 9010.
Also I found out everytime i am executing "copy run start" i get the same error message in the log.
Best Regards
Saikat Chakraborty
Message was edited by: Saikat Chakraborty
Hi Saikat,
Please remove the line
slavesup-bootdisk is a name for flash file system on standby supervisor. While active supervisor can see and access it, standby (in other slot) sees it as its own sup-bootdisk.
Also, booting from another supervisor should not be used as this won't work in case of power down (as standby won't be reachable till the are both booted and synchronized).
Kind Regards,
Ivan Shirshin
**Please grade this post if you find it useful.
Kind Regards,
Ivan
Hi Ivan,
Thank you so much. One more question, if I need to have some redundancy in the boot sequence what can i use instead?
Is disk0: which is an external flash be an option?
Best Regards
Saikat Chakraborty
Hi Saikat,
Sorry for the late response. Yes, you could use the disk0: as next command in boot sequence.
Aru
