Bootvar is showing different images for SP and RP, when I reload the switch to upgrade its not happening
shivacisco123
Feb 27 2018 05:04:44 +11:00  s72033-adventerprisek9-mz.151-2.SY11.bin  - NEW
Nov 23 2015 10:35:32 +11:00  s72033-adventerprisek9-mz.151-2.SY6.bin - OLD
I would like to upgrade to s72033-adventerprisek9-mz.151-2.SY11.bin
FBCCoSw01#remote command switch show bootvar
BOOT variable = disk0:s72033-adventerprisek9-mz.151-2.SY6.bin,1;disk0:s72033-adventerprisek9_wan-mz.122-33.SXI12.bin,1;
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
FBCCoSw01#sh bootvar
BOOT variable = disk0:s72033-adventerprisek9-mz.151-2.SY11.bin,1;disk0:s72033-adventerprisek9-mz.151-2.SY6.bin,1;disk0:s72033-adventerprisek9_wan-mz.122-33.SXI12.bin,1;
Standby not ready to show bootvar
7 Replies 7
shivacisco123
Additional info.
Can some one help me soon please,
Model: WS-6509-E
Module:  WS-SUP720-3B
Serial number:  SAD0851092G
Action taken:
-          Remove and re-type the boot system command
-          Delete and re-copy the IOS version
-          Reboot the system thrice after doing the above
-          Perform the verify /md5
Deepak Kumar
Please check for configuration as:
1. Is new IOS is available on Slavedisk0, if not then copy it?
2. Is redundancy is working fine?
If you have done tasks successfully then you have to forcefully switchover to redundancy and make current standby SE to active SE. After that, you need to follow all steps again to make new bootloader.
Follow the below steps and you will get success.
http://ccieiam.blogspot.ae/2012/03/6500-upgrade-with-redundant-supervisor.html
https://supportforums.cisco.com/t5/lan-switching-and-routing/upgrade-ios-on-redundant-sup-720-s/td-p/695614
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Hello Deepak,
We have only single sup in switch
------------------ show module ------------------
Mod Ports Card Type Model Serial No.
1 4 CEF720 4 port 10-Gigabit Ethernet WS-X6704-10GE SAL09179ZN3
2 8 8 port 1000mb GBIC Enhanced QoS WS-X6408A-GBIC SAL06386ADM
3 8 CEF720 8 port 10GE with DFC WS-X6708-10GE SAL11381CWN
5 2 Supervisor Engine 720 (Active) WS-SUP720-3B SAD0851092G
6 16 CEF720 16 port 10GE WS-X6716-10GE SAL15035AXH
7 48 48-port 10/100 mb RJ45 WS-X6148-RJ-45 SAL06447XCC
8 48 48 port 10/100/1000mb EtherModule WS-X6148-GE-TX SAD075108K8
9 48 48 port 10/100/1000 IEEE 802.3AT WS-X6148E-GE-45AT SAL1551YM49
Sorry,
I didn't get your question it was my bad luck. And thanks for your update. I didn't any solution for you.
Deepak Kumar
Deepak Kumar,
Leo Laohoo
conf t
no boot system flash disk0:s72033-adventerprisek9-mz.151-2.SY6.bin
boot system flash disk0:s72033-adventerprisek9-mz.151-2.SY11.bin
end
wr
reload
Hello Leo,
Thanks for your reply, I can see we had set the Boot variable correctly but still its not showing correctly for SP.
boot-start-marker
boot system flash disk0:s72033-adventerprisek9_wan-mz.122-33.SXI12.bin
boot-end-marker
Hello Leo,
boot-start-marker
