BPDU disabled at interface level
gdwingnuts
I have a Cisco 4948 Catalyst.  We have been asked to configure BPDU globally.  So I believe the command is Switch (config)# spanning-tree portfast bpduguard default.  After entering the the global command is it possible to disable the command on an interface level?  That would save me from having to enable it on each interface.  We may have a linksys switch to connect to the 4948 and at this moment I'm not sure what port it will be.   Thanks for your help!
cb
2 Accepted Solutions
Jon Marshall
When you apply this command globally it is only effective on ports configured with "spanning-tree portfast". So just don't configure the port with portfast.
Jon
Jon Marshall
Jon
Thank you Jon
~cb
Oops one more easy one.  Is the errdisable recovery interval command global or interface specific?
Thanks ahead.
~c
It is a global command -
4500/4900 command reference
Jon
