bpdu guard
dsolangon
Anyone can link me any documentation for bpdu guard on the ff scenarios to the cisco switches
Dual nic pc or server
Ip phones
Wireless access points?
Reza Sharifi
What is ff scenarios?
Can you explain a little more what you are trying to do?
allan.thomas
Level 8
Level 8
Typically you enable BPDU Guard on your edge host posts where you would not ordinarily expect to see BPDUs superior or otherwise. If BPDUs are received on these interfaces the BPDU Guard places the interface into ErrDisable state, thus removing an potential loops being inadvertently introduced into the LAN. Refer to the following link:
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_tech_note09186a008009482f.shtml
Allan.
