RPS light green on 3750 switch
mahesh18
Level 6
Level 6
Hi everyone,
i have standalone 3750 switch.
RPS light is green and system light is off.
3750TS#sh env all
FAN is OK
TEMPERATURE is OK
SW  PID                 Serial#     Status           Sys Pwr  PoE Pwr  Watts
2  Built-in                                         Good
SW  Status          RPS Name          RPS Serial#  RPS Port#
2   Not Present     <>
3750TS#
i have another switch with same model and ios its RPS light is off and system light is green
thanks
mahesh
Hi Mahesh,
So, since the switch is functioning well, then there might be something wrong with the light, faceplate or the mode button which are all cosmetic and should not effect the switch.
Reza
5 Replies 5
Reza Sharifi
Hi Mahesh,
The system light should be green if the system (switch) is functioning correctly.  If you have a Redundant Power Supply in the switch than that RPS light should be green if not, it should be off.
From a 3750-E
Switch#sh env all
FAN is OK
TEMPERATURE is OK
Temperature Value: 34 Degree Celsius
Temperature State: GREEN
Yellow Threshold : 49 Degree Celsius
Red Threshold    : 59 Degree Celsius
1  C3K-PWR-750WAC      DTH1050M0SA  OK              Good     Good     300/420
1   <>              <>
Switch#
Reza
Hi Reza,
I have no redundant power supply.
i will try to put switch back in stack and sees if RPS light changes or not
mahesh
Hi Reza,
I checked both swithes in stack  the switch with RPS light  soild green  i made it as  master switch.
But its system light is still off.
I ran few sh diagnostics command on it all looks ok with the output.
However i found that its mode button is little damaged tilted towards Light hand side.
When i did reload on this switch then System light during boot process shows green for sometime.
To me seems all ok with the switch currently.
Mahesh
Hi Mahesh,
Reza
Hi Reza,
Many thanks again for clearing my doubt.
I can ok with cosmetic issue.
Mahesh
