BPDUGUARD VS BPDUFILTER
gaelfabrice
if we have already set this command " spanning-tree portfast defautl" on a port fa0/2
which command we should enter to prevent BPDU transmission ?
Joseph W. Doherty
If it's an edge port, you often pair BPDUGuard with PortFast, but if you just want to filter BPDU transmissions, you can use BPDUFilter.  I believe, the latter though, can set you up for a L2 loop, so it should be used with great care.
Hello
yes I agree with Joesph the latter I see it has disabling STP which isn't a good option unless you wish to do so!
res
paul
Kind Regards
Paul
thx
thx alot
