BPDUs/unmanged switches...
jimmysands73_2
Level 5
Level 5
Topic at work if unmanged switches send out BPDUs, I didnt think they did.
I grabbed a el cheapo 5 port unmanged switch, connected up my enet notebook connection to the unmanaged switch, turned on wireshark, and never saw any bpdu's ...was this a correct way to test it of does it depend on the unmanaged switch model?
2 Accepted Solutions
lgijssel
Level 9
Level 9
It was the correct way to test...
I'm afraid the results are only valid for the specific brand & type of switch you tested.
At least I would not count on this to make a generic deduction.
regards,
Leo
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
I wouldn't expect to see BPDUs from an unmanaged switch.  If a switch is unmanaged, what STP will it use?  How are port costs and/or root set, etc.
lgijssel
Level 9
Level 9
regards,
Leo
Thanks I will try another one....
Joseph W. Doherty
Disclaimer
Posting
You bring up a good point, I didnt think it through!!
Thanks!
Jimmy
