Bridge Assurance
JimmyChanga007
My apologies if this question has already been asked, I wasn't able to find an answer.
I'm currently studying for my DCCOR and I'm using CML to play with Spanning-tree on some Cisco 9Ks.
When I check for inconsistentports, I see that bridge assurance inconsistencies for specific VLANs. The VLANs impact will be ones that are missing from one of the 3 switches.
My question(s) is, are their scenarios where seeing this is OK, and can be ignored?
I have 3 9Ks connected in a triangle, with one of them (9K-3) is connected to a router. The router connection port is in a VLAN, and an SVI is configured with a /30. Both downstream 9Ks do not have VLAN 100 configured. 9K-1 shows Bridge Assurance Inconsistent for VLAN100.
Another instance I see this is on 9K-1 and 9K-2. They have a VPC configured for VLAN10 which is intended to be used for servers connect to 9K-1 and 9k-2. I don't plan to add devices connected to 9K-3 to VLAN10, so its not configured, but the VLAN is showing inconsistent on 9K-1 and 9K-2.
Is this OK to ignore? Are there configuration best practices I should be following? Should I be configuring something for VLANs they may not be sent to all devices?
balaji.bandi
Can you able to provide the configuration and show vpc output where you see the issue.
also suggest to refer below document for nexus vPC consistency issue :
https://www.cisco.com/c/en/us/support/docs/ios-nx-os-software/nx-os-software/217989-troubleshoot-vpc-inconsistency-issues-on.html
BB
