Bridge between dot1Q & second-dot1q
osgpcqosg
Level 2
Level 2
I'm looking to configure un bridge between :
interface GigabitEthernet0/1.900
   encapsulation dot1Q 1221 second-dot1q 900
and
interface GigabitEthernet0/0.900
   encapsulation dot1Q 900
-I can't use a "ip unnumbered GigabitEthernet0/0.900" because the both interface are ethernet ones.
-My first plan was, but bridge-group 1 is not working for the interface with second-dot1q.
   bridge 1 protocol ieee
     bridge-group 1
     bridge-group 1
Was is the correct way to do this ?
Best regards.
PD:
* I'm using this router to do what:
Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9-M), Version 12.4(24)T5, RELEASE SOFTWARE (fc3)
Cisco 2821 (revision 53.51) with 1036288K/12288K bytes of memory.
0 Replies 0
