egress Netflow - VS-S720-10G
Mauricio Nakano
I'm trying to configure a egress netflow in a 6500 (VSS) with VS-S720-10G supervisor.
I foud some old posts and understood that netflow wasn't supported on 6500 but i found a new document and it seems that netflow is supported in Supervisor Engine 2T:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/white_paper_c11-652021.html
Anybody knows if the netflow still not supported in VS-S720-10G?
It's weird because the command is supported:
#sh run int vlan 4
Building configuration...
Current configuration : 353 bytes
interface Vlan4
ip address X.X.X.X 255.255.0.0
no ip redirects
no ip unreachables
ip directed-broadcast
no ip proxy-arp
ip flow ingress
ip flow egress
ip pim dense-mode
#sh conf | i flow
ip flow-egress input-interface
ip flow ingress layer2-switched vlan 1-6,9-15,17-20,23,40,50,52,87-88,91,94,96,99,102-107,109-110,112-114,116,120-122,125,130,150,176,200-203,250-251,253,270,300-304,600-622,667,704,713-725,729-733,800-828
mls netflow interface
mls flow ip interface-full
ip flow-export source Vlan4
ip flow-export version 9
ip flow-export destination Y.Y.Y.Y 9995
I didn't find any document with this information.
Thanks in advance,
Mauricio Nakano
I'm looking for some documentation.
I'm not sure, but I guess that ip flow egress export capture only egress flows that were software routed.
