broadcast command when using frame relay map
carl_townshend
Hi all, can anyone tell me what the broadcast command does when you configure frame relay maps ?
mahmoodmkl
Level 11
Level 11
It allows the broadcast and multicasts to be forwarded to the specified IP.Generally this is helpful when using routing protocols.
Mahmood
would this not be a unicast then ?
