Broadcom 5720 With Cisco SG300-52 Port
DellPrashant
New Dell server with Broadcom 5720 and latest firmware, connected to CISCO SG300 52 Port switch. When did a loop back on server side shows as 1G port but when connected switch shows as 100 MB. Changed the port still same issue. Another Dell server with 5716 shows 1GB status on switch. OS installed is Windows 2012 R2 (Not sure about the other server). Switch is running on 1.4.2.4. Kindly let us know whether anything needs to be done at the server or switch end to make the status as 1G.
5 Replies 5
What about speed negotiation? Is it Auto or Full? Did you try to force it to 1G ?
Dell - Internal Use - Confidential
No. We wanted to force it but customer denied. So will it be the issue with autonego?
HI Flavio,
The port was set to Auto. Customer wasnt comfortable in setting one port in manual and other in auto.
Also i would like to know if earlier generation servers are detecting it as 1G and not the new generation, does it have anything to do with switch firmware. Do we need to update the switch firmware to support the new generation network chipsets.
I think 1.4.8.06 is the latest firmware, make sure you upgrade to that latest version (page 38 of the attached user guide).
Also, there are numerous options to configure the ports (page 125 in the user guide). Try and change some of the default settings, there might be something the Broadcom doesn't like...
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/sf30x_sg30x/administration_guide/78-19308-01.pdf
Hi All,
The issue came out to be with faulty network cable. When we ran the diagnostics on the port, there was an event with a term "SHORT", so we asked customer to change the cable as we suspected it might be the cable which is getting shorted. So oncec we change the cable the issue got resolved and the port started to show as 1G in Switch.
Thanks for all the help.
