How to configure HSRP between Two 2900 Cisco Router
Youssef_Joe
Hi Guys
I have Two Cisco Router r1,r2 both of them have the same getaway , i need to Achieve the high availability between the two so if r1 down .the r2 should be up and replace r1
see attached the network design
FYI R1 and R2 Shouid Be have The same getway
thanks
Francesco Molino
Let's assume that R1 should be primary and R2 secondary.
Let's also assume your subnet is 192.168.0.0/24 with R1 having ip 192.168.0.2 and R2 has ip 192.168.0.3 and VIP (hsrp) is 192.168.0.1
On R1:
Interface gi0/0
Ip address 192.168.0.2 255.255.255.0
standby 1 ip 192.168.0.1
standby 1 preempt
Standby 1 priority 110
On R2:
Interface gi0/0
Ip address 192.168.0.3 255.255.255.0
standby 1 preempt
Standby 1 priority 90
This is a quick and simple setup. There are other options you can configure like password, decrement based on ipsla...
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Additional to Franscesco's comment, these routers must be able to communicate between them, so you could configure the same vlan on both switches and pass it between them through a trunk interface or use a routing protocol between the devices as well.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
in addition to the Julio's and Francesco's posts, and if your routers support it, you could also consider using GLBP, the advantage being that GLBP load balances traffic over both routers (as opposed to HSRP, where one of the routers is basically in sleep mode, with unused bandwidth). Here is a very basic sample configuration:
R1
interface FastEthernet0/0
 glbp 1 ip 192.168.1.254
R2
 ip address 192.168.1.2 255.255.255.0
