08-17-2022 05:15 AM
I'm trying to setup an 897 router to share a single DSL (with cellular failover) connection among 3 apartments - each with their own access point and VLAN, along with a single guest wifi network. I can connect to the access point and ping the router and internet, but I can't seem to reach the BVI on the access point. I can see the ARP request updating the Mac-address table, but no successful pings in either direction. Config for router and access point attached - any feedback would be appreciated.
The config below is a work in progress - the access points attached to gig2 and gig3 are not yet setup for mbssid (trying to get the 1st access point to behave as expected), and are reachable just fine from the BVI interface. The access-lists on vlan7 and vlan8 are to prevent users from reaching outside of their own networks, and appear to work just fine.
AP3602i_unit_1#sh run
Building configuration...
version 15.3
no service pad
service password-encryption
hostname AP3602i_unit_1
logging rate-limit console 9
enable secret xxxxxxxxxxxxxxxxx
aaa new-model
aaa authentication login default local
aaa authentication ppp default local
aaa authorization exec default local
aaa authorization network default local
aaa session-id common
no ip source-route
no ip cef
ip domain name xxxxxxx
dot11 pause-time 100
dot11 syslog
dot11 vlan-name UNIT_1 vlan 6
dot11 vlan-name UNIT_1_ITS vlan 106
dot11 ssid cisco_wifi_test
vlan 6
authentication open
authentication key-management wpa version 2
mbssid guest-mode
wpa-psk ascii xxxxxx
dot11 ssid guest_wifi
vlan 200
authentication open
mbssid guest-mode
wpa-psk ascii xxxxxxx
no ipv6 cef
username exec_login privilege 15 secret xxxxxxxxxxxx
bridge irb
interface Dot11Radio0
no ip address
shutdown
antenna gain 0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio1
no ip address
encryption mode ciphers aes-ccm
encryption vlan 6 mode ciphers aes-ccm
encryption vlan 200 mode ciphers aes-ccm
ssid guest_wifi
antenna gain 0
peakdetect
no dfs band block
mbssid
channel dfs
station-role root
interface Dot11Radio1.1
encapsulation dot1Q 1 native
bridge-group 1
interface Dot11Radio1.6
encapsulation dot1Q 6
bridge-group 6
bridge-group 6 subscriber-loop-control
bridge-group 6 spanning-disabled
bridge-group 6 block-unknown-source
no bridge-group 6 source-learning
no bridge-group 6 unicast-flooding
interface Dot11Radio1.200
encapsulation dot1Q 200
bridge-group 200
bridge-group 200 subscriber-loop-control
bridge-group 200 spanning-disabled
bridge-group 200 block-unknown-source
no bridge-group 200 source-learning
no bridge-group 200 unicast-flooding
interface GigabitEthernet0
no ip address
duplex auto
speed auto
interface GigabitEthernet0.1
bridge-group 1
interface GigabitEthernet0.6
bridge-group 6
interface GigabitEthernet0.200
bridge-group 200
interface BVI1
mac-address xxxx.xxxx.xxxx
no ip address
interface BVI6
ip address 10.1.6.20 255.255.255.0
interface BVI200
ip address 172.16.16.20 255.255.255.0
ip forward-protocol nd
ip http server
no ip http secure-server
ip ssh version 2
bridge 1 route ip
bridge 6 route ip
line con 0
exec-timeout 0 0
line vty 0 4
transport input ssh
end
R897VAG-LTE Building configuration...
version 15.5
hostname R897VAG-LTE_base
boot-start-marker
boot-end-marker
aaa new-model
ethernet lmi ce
clock timezone AEST 10 0
ip dhcp excluded-address 10.1.6.1 10.1.6.69
ip dhcp excluded-address 10.1.7.1 10.1.7.69
ip dhcp excluded-address 10.1.8.1 10.1.8.69
ip dhcp pool ITS_UNIT_1
network 10.1.106.0 255.255.255.0
default-router 10.1.106.1
dns-server 1.1.1.1 76.76.19.19 8.8.4.4 8.8.8.8
option 150 ip 10.1.106.1
ip dhcp pool ITS_UNIT_2
network 10.1.107.0 255.255.255.0
default-router 10.1.107.1
option 150 ip 10.1.107.1
ip dhcp pool ITS_UNIT_3
network 10.1.108.0 255.255.255.0
default-router 10.1.108.1
option 150 ip 10.1.108.1
ip dhcp pool PC_UNIT_1
network 10.1.6.0 255.255.255.0
default-router 10.1.6.1
ip dhcp pool PC_UNIT_2
network 10.1.7.0 255.255.255.0
default-router 10.1.7.1
ip dhcp pool PC_UNIT_3
network 10.1.8.0 255.255.255.0
default-router 10.1.8.1
ip dhcp pool GUEST_WIFI
network 172.16.16.0 255.255.255.0
default-router 172.16.16.1
ip dhcp pool tftp_server
host 10.1.6.69 255.255.255.0
client-identifier xxxxxx
ip dhcp pool raspberrypi
host 10.1.6.50 255.255.255.0
client-identifier xxxxxxx
ip domain name xxxxxxxx
ip cef
login block-for 120 attempts 2 within 120
login delay 10
login quiet-mode access-class 10
login on-failure log
login on-success log
no ipv6 cef
chat-script lte "" "AT!CALL" TIMEOUT 20 "OK"
license udi pid xxxxxxxx
archive
path tftp://10.1.6.50/$h-$t
vtp mode transparent
username exec_login xxxxxxxxxx
controller VDSL 0
operating mode vdsl2
firmware filename flash:VA_A_39t_B_35j_24m
controller Cellular 0
lte sim data-profile 1 attach-profile 1 slot 0
no lte gps enable
lte modem link-recovery rssi onset-threshold -110
lte modem link-recovery monitor-timer 20
lte modem link-recovery wait-timer 10
lte modem link-recovery debounce-count 6
description WWAN_failover
vlan 6
name UNIT_1
vlan 7
name UNIT_2
vlan 8
name UNIT_3
vlan 106
name UNIT_1_ITS
vlan 107
name UNIT_2_ITS
vlan 108
name UNIT_3_ITS
vlan 200
name GUEST
track 1 ip sla 1
crypto isakmp policy 1
encr aes
hash sha256
authentication pre-share
group 2
crypto isakmp key xxxxxxx address xxxxxxxx
crypto ipsec transform-set transform-AES-SHA esp-aes esp-sha256-hmac
mode tunnel
crypto map CMAP 10 ipsec-isakmp
description xxxxx
set peer xxxxxxx
set transform-set transform-AES-SHA
match address VPN-1
crypto map CMAP 20 ipsec-isakmp
description xxxxxx
set peer xxxxxxxxx
match address VPN-2
interface Loopback0
ip address 10.10.10.6 255.255.255.255
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface Cellular0
description xxxxxxx
ip address negotiated
ip access-group 199 in
ip nat outside
ip virtual-reassembly in
encapsulation slip
dialer in-band
dialer idle-timeout 0
dialer string lte
dialer-group 2
interface Cellular1
no ip address
encapsulation slip
interface Ethernet0
description xxxxxxxx
ip dhcp client route track 1
ip address dhcp
ip nat outside
crypto map CMAP
switchport access vlan 6
switchport voice vlan 106
no ip address
interface GigabitEthernet1
description UNIT_1_AP3702i
switchport mode trunk
no ip address
interface GigabitEthernet2
description UNIT_2_AP3702i
switchport access vlan 7
switchport voice vlan 107
no ip address
interface GigabitEthernet3
description UNIT_3_AP3702i
switchport access vlan 8
switchport voice vlan 108
no ip address
interface GigabitEthernet4
no ip address
interface GigabitEthernet5
no ip address
interface GigabitEthernet6
no ip address
interface GigabitEthernet7
no ip address
interface GigabitEthernet8
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
no ip address
ip nat inside
interface Vlan6
ip address 10.1.6.1 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
interface Vlan7
ip address 10.1.7.1 255.255.255.0
ip access-group 107 in
ip nat inside
interface Vlan8
ip address 10.1.8.1 255.255.255.0
ip access-group 108 in
ip nat inside
interface Vlan106
ip address 10.1.106.1 255.255.255.0
ip nat inside
interface Vlan107
ip address 10.1.107.1 255.255.255.0
ip nat inside
interface Vlan108
ip address 10.1.108.1 255.255.255.0
ip nat inside
interface Vlan200
ip address 172.16.16.1 255.255.255.0
ip nat inside
no ip http server
ip nat inside source route-map route1 interface Ethernet0 overload
ip nat inside source route-map route2 interface Cellular0 overload
ip route 0.0.0.0 0.0.0.0 Cellular0 100
ip route 8.8.4.4 255.255.255.255 Cellular0
ip route 0.0.0.0 0.0.0.0 dhcp
ip route 8.8.8.8 255.255.255.255 dhcp
ip ssh version 2
ip access-list extended VPN-1
permit ip 10.1.6.0 0.0.0.255 10.1.1.0 0.0.0.255
permit ip 10.1.6.0 0.0.0.255 10.1.101.0 0.0.0.255
permit ip 10.1.106.0 0.0.0.255 10.1.1.0 0.0.0.255
permit ip 10.1.106.0 0.0.0.255 10.1.101.0 0.0.0.255
ip access-list extended VPN-2
permit ip 10.1.6.0 0.0.0.255 10.1.2.0 0.0.0.255
permit ip 10.1.6.0 0.0.0.255 10.1.102.0 0.0.0.255
permit ip 10.1.106.0 0.0.0.255 10.1.2.0 0.0.0.255
permit ip 10.1.106.0 0.0.0.255 10.1.102.0 0.0.0.255
ip sla 1
icmp-echo 8.8.8.8 source-interface Ethernet0
ip sla schedule 1 life forever start-time now
dialer-list 2 protocol ip permit
route-map route1 permit 10
match ip address 100
match interface Ethernet0
route-map route2 permit 10
match interface Cellular0
access-list 10 permit 10.1.6.0 0.0.0.255
access-list 100 deny ip any 10.1.5.0 0.0.0.255
access-list 100 deny ip any 10.1.105.0 0.0.0.255
access-list 100 deny ip any 10.1.4.0 0.0.0.255
access-list 100 deny ip any 10.1.104.0 0.0.0.255
access-list 100 deny ip any 10.1.3.0 0.0.0.255
access-list 100 deny ip any 10.1.103.0 0.0.0.255
access-list 100 deny ip any 10.1.2.0 0.0.0.255
access-list 100 deny ip any 10.1.102.0 0.0.0.255
access-list 100 deny ip any 10.1.1.0 0.0.0.255
access-list 100 deny ip any 10.1.101.0 0.0.0.255
access-list 100 permit ip 10.1.6.0 0.0.0.255 any
access-list 100 permit ip 10.1.106.0 0.0.0.255 any
access-list 100 permit ip 10.1.7.0 0.0.0.255 any
access-list 100 permit ip 10.1.107.0 0.0.0.255 any
access-list 100 permit ip 10.1.8.0 0.0.0.255 any
access-list 100 permit ip 10.1.108.0 0.0.0.255 any
access-list 100 permit ip 172.16.16.0 0.0.0.255 any
access-list 107 permit ip any 10.1.7.0 0.0.0.255
access-list 107 deny ip any 10.1.0.0 0.0.255.255
access-list 107 permit ip any any
access-list 108 permit ip any 10.1.8.0 0.0.0.255
access-list 108 deny ip any 10.1.0.0 0.0.255.255
access-list 108 permit ip any any
access-list 199 deny tcp any any eq www
access-list 199 deny tcp any any eq 1720
access-list 199 deny tcp any any eq 5060
access-list 199 deny udp any any eq 5060
access-list 199 permit ip any any
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
exec-timeout 0 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
stopbits 1
line 3
script dialer lte
no exec
speed 384000
line 8
no exec
speed 384000
line vty 0 4
exec-timeout 0 0
transport input ssh
scheduler allocate 20000 1000
ntp server xxxxxxx
end
