Hello!
From the description you need only egress policing on SVI interface of vlan
traffic to which you want to limit.
Do you still have the problem?
There are some restrictions, but it should work, see:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/qos.html#wp1727272
So could you post you config of:
- input and output phy interface;
- input and output int SVI;
- Used class-map config (better to use ACL in some class, for example standard one like "access-list 1 permit any");
- Used egress policy-map config
- Output of "sh mls qos ip", "show mls qos", "show policy int SVIx"
Sergey
