C1000 stack LACP problem
Wei Ting Lin
Frequent Visitor
Frequent Visitor
Hi all
I stacked two C1000s, and set gi2/0/39-40 as etherchannel, the interface is default config,
but an error message appears, do I need to do other settings?
switch(config)#interface range gi2/0/39-40
switch(config-if-range)# switchport mode trunk
switch(config-if-range)# channel-group 1 mode active
Command rejected (Port-channel1, Gi2/0/39): Command execution failed on one or more switches
% Range command terminated because it failed on GigabitEthernet2/0/39
Device is C1000-48P-4X-L *2
version is 15.2(7)E4
7 Replies 7
Mark Elsen
 - Could you try channel-group 1 mode on, and or look into using the latest advisory release too : https://software.cisco.com/download/home/286324209/type/280805680/release/15.2.7E6
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Wei Ting Lin
Frequent Visitor
Frequent Visitor
I tested mode on, but it still doesn't work, and the release note didn't mention similar bugs.
I will try to test the new version.
Wei Ting Lin
Frequent Visitor
Frequent Visitor
i try upgrade to 15.2(7)E6 , the problem is slove.
thanks for sharing solution.
Hello
Etherchannel can suffer from an order or operation in the way they are created, suggest do the following:
L2 etherchannel
1) default physical interfaces (if possible)
2) configure port-channel in physical interfaces
-- port-channel will be created automatically
3)create trunking encapsulation or access port mode directly in port-channel interface
4)enable physical interfaces "no shut"
Example:
conf t
default int ran gig0/1 -2 ( if applicable)
int ran gi0/1 -2
shut ( if applicable)
channel-group 1 mode xxx
int port-channel 1
switchport trunk encap dot1q
switchport- mode trunk
no shut
or
switchport vlan 123
swithport mode access
no shut
Kind Regards
Paul
I have tried your way, but the device still shows command error.
Hello
If the error ONLY pertains to the interface range command, then could be cosmetric to the software train you are using and indeed upgrading that software solves the problem.
Kind Regards
Paul
