C1000 web console issues after upgrade
j.dunsmore
I have a C1000-16P-E-2G-L.. and have tried to upgrade to the most current iOS which currently is 15.2.7E4
Every time i try, the upgrade completes (using USB) and the web interface turns out like this.
The header is garbled, obviously missing some sort of reference, and there is a missing image underneath the left hand menu.
Any ideas? Ive never seen this before on the Web interface.. If i go back to E2 everything goes back to normal.
Cheers
had the same Problem with my brand new C1000-16P-2G-L which curiously came preinistalled with iOS 15.2.8E (not yet available on the C1000 Download section!).
The top menu on the GUI looked like shown on the screenshot in the first posting. Hyperlinks on this menu were not working.
After trying different iOS Releases (i've even downgraded to 15.2.7E2) with no success, i finally returned to the currently recommended version 15.2.7E4.
After studying the Release Notes, i stumbled over this hint: https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst1000/software/releases/15_2_7_e/release_notes/ol_15_2_7_e_c1000.html#concept_ghx_wjh_5qb
There was already a priviledge 15 user configured, so i've added "ip http authentication local" to the config, and it finally resolved this annoying Issue
Best regards,
    Marcus
11 Replies 11
Mark Elsen
                   - As a sanity check try different browser(s)
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
j.dunsmore
Yeah, tried Safari + Chrome on MacOS and iOS..
Also tried Chrome+Edge on Win10
Cleared caches too.
Same result!
 - Check the logs when trying to access the web console , perhaps more info can be found.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Mark Elsen
                    - Ref : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvo35537
   Check if the bug Conditions apply to your configuration (too). If so , then implement the suggested Workaround.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
j.dunsmore
Hi, and thanks for the further reply.
Have enabled log level 7 and attempted again, nothing showed in log.
also
changed to the suggested 'service timestamps log datetime' - unfortunately still the same
service timestamps are currently set as follows.
no service timestamps debug uptime
tried combinations of the service timestamps too.
Cheers
 - Ok, it should be considered as cosmetic  I guess, meaning that  the rest of the gui should work.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
j.dunsmore
Yeah, i totally agree with you, but if someone gets a new switch with this revision of SW, and especially as a beginner they would be really confused seeing that.
Im not bothered really since i normally use the CLI for everything, but it would be nice to see the GUI working as expected. Interesting as well that it worked ok in version E2
I dont have access to log a TAC for it either.
Best regards,
    Marcus
Hi Marcus
Excellent. Well found, i never noticed that before (or its just been added) ! That worked and the GUI is back to normal!
As has been said before, its only cosmetic, but non CLI users would run into major confusion seeing all the garbage on screen.
Cheers
John
That fixed it for me! To get to configure I had to use SeaMonkey browser which works well with poor CORS policies.
Thank you for the permanent fix, Chrome now works properly.
Marcus S.
Hi John,
Thank You, you're very welcome
I aggree, this is cosmetic and not that relevant to users like us.
But nevertheless, when You are buying an expensive switch from the market leader, you expect to get a product that is free of glitches or blemishes like this. As i said, in my case i had this issue "out of the box" with the factory setting. So without knowing the cause, this issue easily leaves the impression of a not so well reasoned product to new or unexperienced customers.
So in my opinion this missing config excerpt should be set by factory default, in order not to leave new customers annoyed.
Best regards
    Marcus
