Moving clients from a dummy switch to a managed switch
S3C
Setup:
FW -> Dummy Switch -> 3 clients (GW is the FW port)
I have a managed switch where ive configured 3 ports as access and vlan x untagged. I want to remove the dummy switch and put these 3 clients on the managed one.
My mind is totally blank at the moment, cant think of what im doing wrong hence the question
As the 3 ports are access mode, same vlan and untagged, shouldnt it then act as the same way as a dummy switch?
S3C
Fixed it, the ports was in protected state ^^
Hello
@S3C wrote:
FW -> Dummy Switch -> 3 clients (GW is the FW port)As the 3 ports are access mode, same vlan and untagged, shouldnt it then act as the same way as a dummy switch?
Just plug them in the manage switch and that should work straight away, however you can make a little change to the ports.
switch
int x/x
switchport mode access
spanning-tree portfast
no shut
Kind Regards
Paul
