c1300 autobackup
sanjar200994
Frequent Visitor
Frequent Visitor
Hello, we bought c1300 switch
there is no "archive" command, is there any way to autobackup this switches via TFTP?LAN Switching, с1300
@sanjar200994
 As per the link below, archive is not supported on this switch model.
https://www.cisco.com/c/en/us/td/docs/switches/campus-lan-switches-access/Catalyst-1200-and-1300-Switches/cli/C1300-cli.pdf
The option you have is copy the config to tftp manually or you can run a script to connect to the switch and run the backup accordingly.
You can use Ansible to backup configurations for your Cisco equipment:
https://developer.cisco.com/codeexchange/github/repo/sachin0987/Cisco-Device-Backup-Ansible/
Regards, LG
*** Please Rate All Helpful Responses ***
Hello
cron/eem scripting would do the trick
Kind Regards
Paul
