How to enter the ROMMON mode in 2960x switch?
gowdakssujan
7 Replies 7
pieterh
2960x is not mentioned in below document, but procedure is the same
Recover Catalyst Fixed Configuration Switches from a Corrupted Image - Cisco
1.Connect console to switch.
2. Hold Down the Mode Button on the front of the switch
3. Power up the Switch whilst keeping the mode button held in
4. wait to display 'USB Console INIT' on console and release mode button
Good luck
KB
gowdakssujan
any short cut keys(ex: break, ctrl+shift+6.....) ??
no, the procedure is as described.
you need physical access to the switch to power down/up and activate the button
you need physical access anyhow to access the serial console port ?
gowdakssujan
while switch is rebooting, we can break the rebooting process right, to avoid the switch booting from flash
Yes, using the button:
This worked for me as well. Thanks!
