c2600 Platform
I bought a 2600 router and the int fa0/0 does not work. I get connect link light when plugged into another port but it isn't seen from cdp on the switch. As I investigated into the problem on the show version it says the platform is a 2600. Is there such a thing ... I thought it 2600 was the family and they were broken out by the last two digits ... such as 2610, 2612, 2620, 2650, and 2691?
Before I open it up and do the obvious physical checkout of the interface, can y'all check the CLI for anything obvious?
Richard
Router#sho ver
IOS (tm) C2600 Software (C2600-I-M), Version 12.1(7), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Thu 22-Feb-01 12:50 by kellythw
Image text-base: 0x80008088, data-base: 0x808023C4
ROM: System Bootstrap, Version 12.1(3r)T2, RELEASE SOFTWARE (fc1)
Router uptime is 2 minutes
System image file is "flash:c2600-i-mz.121-7.bin"
cisco 2600 (MPC860) processor (revision 0x200) with 39936K/9216K bytes of memory.
Processor board ID JAB05450DNU (876670445)
M860 processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Router#sho flash:
System flash directory:
File Length Name/status
1 4428372 c2600-i-mz.121-7.bin
[4428436 bytes used, 12348780 available, 16777216 total]
Router#sho int
Router#sho controll
Router#
Router#sho run
Building configuration...
Current configuration : 308 bytes
version 12.1
service timestamps debug uptime
service timestamps log uptime
no service dhcp
hostname Router
ip subnet-zero
no ip finger
ip classless
ip http server
line con 0
transport input none
line aux 0
line vty 0 4
no scheduler allocate
end
Router#
Sorry...forgot about that. Can you update the IOS? If you can I would try that and get it for the 2650. I will check out a couple other things.
Mike
25 Replies 25
Edison Ortiz
Richard,
Post the show diag output.
__
Edison.
Edison,
Everytime I boot the router up the following message is displayed which is one I have never seen.
00:00:003: %LINK-4-MOMAC: A random default MAC address of 000.0c83.eded has been chosen. Ensure that this address is unique, or specify MAC addresses for commands (such as 'novell routing') that allow the use of this address as a default.
The router diag shows nothing ...
Router#sho diag
Router#
Trying to think of ways to use a router that has no working interfaces. I guess I could use it to make sure all the other 2600's are the right size.
Richard
Richard
From several things, especially from the fact that the show version does not indicate the presence of any interfaces I am guessing that the image that you are running is not the correct image for this piece of hardware. Perhaps you have a 2600XM and are running software for 2600 (or have a 2600 and are running software for 2600XM). Perhaps if you would post the complete set of messages when the router boots it might give us some insight about the problem.
Rick
Rick
Rick,
Thanks for the help. Here it is ...
Copyright (c) 2000 by cisco Systems, Inc.
C2600 platform with 49152 Kbytes of main memory
program load complete, entry point: 0x80008000, size: 0x439138
Self decompressing the image : ############################################################################################
############################################## [OK]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Bridging software.
Press RETURN to get started!
00:00:03: %LINK-4-NOMAC: A random default MAC address of 0000.0c83.eded has
00:00:07: %SYS-5-RESTART: System restarted --
00:00:07: %DHCPD-2-SOCKET_ERROR: DHCP could not open UDP port 67.
Router>
What interface cards do you have installed in the chassis? Also on the back by the power switch there should be a sticker that goes around the AUX, Console, and FastEthernet ports, on that sticker it should tell you the model number.
Mike
Mike,
Learn something new everyday ... never ever noticed that sticker before on any routers. It is a 2650 and there are no interfaces installed (no modules) other than the platform standard fa, con, and aux.
Richard
That is why you do not see any interfaces....there are not any installed. You will need to get a module installed to connect them up.
Mike
Mike,
The router has a fastethernet port that is standard for all 2600 platforms. There are no 'modules' installed on the router. The fastethernet port is not in the CLI ... that is the problem I am trying to fix. Unless I am misunderstanding you, the port is standard to the platform and is not a module.
Richard
Mike
Mike,
I would but I don't have access to cisco downloads and don't have a 2650 IOS. I have to wait until after the holidays to try and get it from work.
Richard
Can you run show tech on the router and post it.
Mike
Richard,
With the help of Rick and Mike, I was able to determine that you are indeed running the wrong code for a 2650.
2650 support started with 12.1(T) and you are running 12.1(Mainline).
You have limited DRAM (48) but you should be able to load this code in your router:
c2600-i-mz.123-26.bin
HTH,
__
Edison.
Edison,
Thanks. How exactly did you deduce that ... just so I can understand that in the future. All I was able to do was go to the cisco download site and look for the IOS I have in the router now but couldn't find it. I wasn't really able to tell if it was wrong or not. Is there something in the router output that points to that?
Richard
Richard,
Part of your Cisco learning should include mastering the Release Notes as well as the Feature Navigator 🙂
I went to the Cisco Feature Navigator and noticed there weren't 12.1(M) IOS available for 2650, then I double-checked my suspicious by going to the Release Notes on 12.1 and 12.2.
See the 2600 supported platforms in 12.1
http://www.cisco.com/en/US/docs/ios/12_1/relnotes/crossplatform/release/notes/121FEATS.html#wp37630
See the 2600 supported platforms in 12.2
http://www.cisco.com/en/US/docs/ios/12_2/release/notes/122feats.html#wp34883
With clearer information here:
http://www.cisco.com/en/US/docs/ios/12_2/release/notes/122newf.html#wp27914
HTH,
__
Edison.
