Setting up Frame Relay
dhopper82
I have a 2811 router that I am trying to run a test on for a project. I have been given a NM-HDV2-2T1/E1. Can I set up frame relay on this and if so how would I do it? Here is a sample of the commands I would like to use...
On physical interface
mtu 4400
no ip address
encapsulation frame-relay IETF
ip route-cache flow
frame-relay lmi-type ansi
On sub-interface...
interface Serial0/0.476 point-to-point
description PPVC SC100
bandwidth 128
ip address 10.98.44.1 255.255.255.0
traffic-shape rate 128000 7936 7936 1000
traffic-shape adaptive 96000
frame-relay class primary
Can this be done using that module??
Dennis,
Here is a comprehensive doc on how to configure frame-relay. If you understand the basics of configuring frame-relay, it should help you configure FR on your interface.
http://www.cisco.com/en/US/tech/tk713/tk237/technologies_tech_note09186a008014f8a7.shtml
You might also want to know about issues with frame-relay inverse arp from the above doc.
Edison Ortiz
As long as you fit the Network Module above with a VWIC module, not a VIC module - the router configuration will display the serial interfaces and you should be able to configure it, just as you illustrated.
http://www.cisco.com/en/US/products/hw/modules/ps5365/products_data_sheet09186a0080191d41.html
HTH,
__
Edison.
Thanks, it has a VIC module in it now. I'll see about getting a replacement.
Dennis
There is an aspect of your original post that may need some clarification. In the original post you state:"I am trying to run a test on for a project". If the 2811 will connect on its serial interface to an active Frame Relay switch then yes your suggested configuration should work. If your test does not include an active Frame Relay switch then it will not work as configured. There are ways to set up routers back to back (the typical test scenario) and run Frame Relay, but it requires some different configuration than what you have got.
So is there an active Frame Relay switch you will connect to or not?
Rick
Rick
