C2960 Command not supported
Gerard Daly
Community Member
Does anyone know why the C2960 does not support the command ip tacacs source-interface?
I am running C2960-LANBASEK9-M), Version 12.2(44)SE  have multiple VLANs and want to specify my source traffic for TACACs.
Many thanks in advance,
Gerry
subma
Hi Gerard,
The issue is because of the below bug
CSCsm28901
"ip tacacs source-interface" command missing in 12.2.44SE.
Symptom:
The "ip tacacs source-interface" command is missing in 12.2(44)SE
Workaround:
Configure the source-interface under the TACACS server group.
Example:
Switch(config)# aaa group server tacacs+ test
Switch(config-sg-tacacs+)# ip tacacs source-interface Vlan1
Switch(config-sg-tacacs+)# exit
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?caller=pluginredirector&method=fetchBugDetails&bugId=CSCsm28901
This bug is known to be fixed in 12.2(44)SE2
let me know how this works out for you.
Subbiah
subma
Hi Gerard,
CSCsm28901
Symptom:
Workaround:
Example:
Subbiah
Hi Subbiah,
Many thanks for that!
Will let you know how it goes,
Best Regards,
Gerard
Hi Subbiah,
That worked a treat!
Thanks again,
Best Regards,
Gerard
Hi Gerard,
Thanks for keeping me posted. Glad to hear that.
Have a good one
Subbiah
