C2960s ip routing problem
Atalec
I've a problem when I want to enable the IP routing on my switch I've this error
"%PLATFORM_UCAST-3-INV_SDM: IP routing configured with invalid SDM template."
I changed my prefered SDM by Lanbase-routing
 The current template is "lanbase-routing" template.
 The selected template optimizes the resources in
 the switch to support this level of features for
 0 routed interfaces and 255 VLANs.
  number of unicast mac addresses:                  4K
  number of IPv4 IGMP groups + multicast routes:    0.25K
  number of IPv4 unicast routes:                    0.875k
    number of directly-connected IPv4 hosts:        0.875k
    number of indirect IPv4 routes:                 16
  number of IPv6 multicast groups:                  0.25K
  number of IPv6 unicast routes:                    0.75K
    number of directly-connected IPv6 addresses:    0.75K
    number of indirect IPv6 unicast routes:         16
  number of IPv4 policy based routing aces:         0
  number of IPv4/MAC qos aces:                      0.375k
  number of IPv4/MAC security aces:                 0.375k
  number of IPv6 policy based routing aces:         0
  number of IPv6 qos aces:                          0.125k
  number of IPv6 security aces:                     0.25K
Do you know this problem and to solve it ?
PLease
Thx
balaji.bandi
what license you have - can you post show version ?
BB
Hello
Have you reloaded the switch, no also that SDM template will only allow static routes and SVI enablement, nothing more.
Kind Regards
Paul
I believe that @paul driver is on the right track. If his suggestions do not resolve the question then it would be helpful to see a copy of the current running config and also to know exactly what command was entered that generated that error message.
Rick
If you are trying to enable dynamic routing protocols I think you would need the IP license.
