c2960x - Web interface load blank page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
08-04-2020 03:32 AM
I read some of the similar threads here, but non of them solved my issue.
When trying to access the web interface it will just show up the blank(white) page.
We have 6x 2960X-24TS-LL, IOS version 15.2.7E2 with web and on all is the same.
We already upgraded the IOS version which include the web interface.
I've also tried Chrome, IE, Mozilla and same for all, also updated the java to newest version(not sure if its needed).
Web interface is allowed in config:
ip http server
ip http secure-server
I suspecting something on the server side, but not sure what.
Help is appreciated.
Thanks.
- Labels:
Catalyst 2000
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-04-2020 05:07 AM
Is java enabled? have you installed TAR file?
Here is complete guide: https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-0_2_EX/security/configuration_guide/b_sec_152ex_2960-x_cg/b_sec_152ex_2960-x_cg_chapter_01010.html
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-04-2020 05:58 AM
Yes, Java is enabled and TAR file installed, as I said we installed the IOS with web support.
The guide which you mentioned is for SSL configuration, but for me it doesn't work either via http.
I would like to first verify its working at least via http before I will start another configurations.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-04-2020 06:00 AM
What is error message on the browser?
Post the complete output to the command "dir" and "sh version".
Deepak Kumar,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-04-2020 06:11 AM
sh version:
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.2(7)E2, R ELEASE SOFTWARE (fc3)
Copyright (c) 1986-2020 by Cisco Systems, Inc.
Compiled Sat 14-Mar-20 16:53 by prod_rel_team
ROM: Bootstrap program is C2960X boot loader
BOOTLDR: C2960X Boot Loader (C2960X-HBOOT-M) Version 15.2(6r)E, RELEASE SOFTWARE (fc1)
PSN001 uptime is 3 days, 22 hours, 21 minutes
System restarted at 14:46:11 UTC Fri Jul 31 2020
System image file is "flash:/c2960x-universalk9-mz.152-7.E2/c2960x-universalk9-m z.152-7.E2.bin"
Last reload reason: Reload command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960X-24TS-LL (APM86XXX) processor (revision E0) with 262144K bytes of memory.
Processor board ID FJT2404102X
Last reset from power-on
1 Virtual Ethernet interface
1 FastEthernet interface
26 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 24:16:9D:90:BF:00
Motherboard assembly number : 73-16697-05
Power supply part number : 341-0529-02
Motherboard serial number : FJZ24020PRS
Power supply serial number : LIT232337M2
Model revision number : E0
Motherboard revision number : D0
Model number : WS-C2960X-24TSLL++
Daughterboard assembly number : 73-14200-03
Daughterboard serial number : FJZ24031E8H
System serial number : FJT2404102X
Top Assembly Part Number : 68-100876-02
Top Assembly Revision Number : K0
Version ID : V02
Daughterboard revision number : B0
Hardware Board Revision Number : 0x19
Switch Ports Model SW Version SW Image
* 1 26 WS-C2960X-24TS-LL 15.2(7)E2 C2960X-UNIVERSALK9-M
Configuration register is 0xF
dir:
Directory of flash:/
2 -rwx 2044 Jul 31 2020 14:47:37 +00:00 config.text
3 -rwx 3403 Jul 31 2020 14:47:37 +00:00 private-config.text
4 -rwx 3096 Jul 31 2020 14:47:37 +00:00 multiple-fs
5 drwx 512 Jul 31 2020 13:47:00 +00:00 c2960x-universalk9-mz.152-7.E2
496 drwx 512 Jul 31 2020 13:47:01 +00:00 dc_profile_dir
56125440 bytes total (14505472 bytes free)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-04-2020 11:21 PM
I can see the directory for this version also hoping the HTML directory will also there. Otherwise, you will get a "not found" error message.
1. Have you tried on any other client machine? Is your system Antivirus software blocking any java stuff?
2. Have you recently updated any IOS?
3. run the debug on the switch and share logs.
Deepak Kumar,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-06-2020 01:26 AM
Yes, the HTML directory is there.
dir c2960x-universalk9-mz.152-7.E2:
Directory of flash:/c2960x-universalk9-mz.152-7.E2/
6 drwx 1536 Jul 31 2020 13:26:10 +00:00 html
494 -rwx 688 Jul 31 2020 13:31:38 +00:00 info
495 -rwx 26665984 Jul 31 2020 13:31:38 +00:00 c2960x-universalk9-mz.152-7.E2.bin
1. Yes, I tried from multiple machines
2. Yes, I've updated to the newest version. Before there was IOS without web interface support.
3. Which debugging do you mean? #debug all?
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-04-2020 08:38 AM
- Try to fetch the page with wget and turn on debugging, you may get more info ,
M.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-06-2020 01:25 AM
Share your configuration.
Deepak Kumar,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-06-2020 01:55 AM
Here it is, I keep it at minimum now to first resolve the problem.
#sh run
Current configuration : 3311 bytes
! Last configuration change at 10:47:29 UTC Wed Aug 5 2020
version 15.2
no service pad
hostname HOSTNAME
boot-start-marker
boot-end-marker
enable secret 5 --------------------------
enable password ---------------
username USERNAME privilege 15 secret 9 -----------------------
no aaa new-model
crypto pki trustpoint TP-self-signed-2643508992
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2643508992
revocation-check none
rsakeypair TP-self-signed-2643508992
crypto pki certificate chain TP-self-signed-2643508992
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 32363433 35303839 3932301E 170D3230 30373331 31343437
33365A17 0D333030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 36343335
30383939 3230819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100AE2B D22BBD64 F2CF54AE 5FC7A15A 7768CB4F EF798ED5 FFE23C5D 5217F4FF
353808B4 0E9F418A 9088FEC6 CCDB220C D79461AA B1604F78 DA04CCAB A5A6C238
CA98EFB9 58F1D153 153355EE 26DA67E5 2D6E8977 8D591D12 4AF13148 9A2AC6E2
B0BAC0FB E0789BE3 2DE18AC9 223CB606 FC84CFCC 0892A619 CE16B9DC 94590680
356D0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 14CD000F F1F1B71B 8495714A CA050EED C86D5DB6 A6301D06
03551D0E 04160414 CD000FF1 F1B71B84 95714ACA 050EEDC8 6D5DB6A6 300D0609
2A864886 F70D0101 05050003 818100A5 EB17FC27 527013AB 5F0740C2 F9D67CBA
9BB2D622 AA1DCDC6 6CA9DED9 348036A1 962DF16D D67EFF4E 2E6DEF52 C59FBDD5
52794A9E 5185ED6A D10D5B04 486D3564 DFF352BA E932A941 CD50C5B1 3939DEB9
BE647434 C1C9FD87 676ACAB8 0CC5D7FB D2B8EF31 FF158849 455E7BBA 9ABF4608
58D84F48 50506B4C 0996FC02 1A63A8
quit
spanning-tree mode rapid-pvst
vlan internal allocation policy ascending
interface FastEthernet0
no ip address
shutdown
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface Vlan1
ip address 111.11.1.111 255.255.252.0
ip http server
no ip http secure-server
line con 0
password PASSWORD
line vty 0 4
password PASSWORD
login
line vty 5 15
password PASSWORD
login
end
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-16-2021 06:21 AM
Hi!
Did resolve this issue? And if yes, would you mind telling me how you did it?
I'm having the same problem.
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-16-2021 06:44 AM
Only solution for me was to use different/older release of firmware, not really ideal.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-16-2021 12:26 PM
Thanks!
I'll keep that in mind.
Will try and put html folder in the root folder instead of the IOS version folder.
probably won't solve it, but want to try it, so I can't say to myself that I didn't try everything.
Again thanks again and if it works i'll let you know.
Cheers!
