C2960XR to C9200L MLS Configuration
tweep9141983
Not a QoS expert here but I am really trying to study and understand at the moment.  We have added a new C9200L to our office and I am stuck with configuring the MLS part..
Below is the existing config in the C2960XR
mls qos map cos-dscp 0 8 16 24 32 46 48 56
mls qos srr-queue output cos-map queue 1 threshold 3 4 5
mls qos srr-queue output cos-map queue 2 threshold 1 2
mls qos srr-queue output cos-map queue 2 threshold 2 3
mls qos srr-queue output cos-map queue 2 threshold 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 0
mls qos srr-queue output cos-map queue 4 threshold 3 1
mls qos srr-queue output dscp-map queue 1 threshold 3 32 33 40 41 42 43 44 45
mls qos srr-queue output dscp-map queue 1 threshold 3 46 47
mls qos srr-queue output dscp-map queue 2 threshold 1 16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 2 threshold 1 26 27 28 29 30 31 34 35
mls qos srr-queue output dscp-map queue 2 threshold 1 36 37 38 39
mls qos srr-queue output dscp-map queue 2 threshold 2 24
mls qos srr-queue output dscp-map queue 2 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3 0 1 2 3 4 5 6 7
mls qos srr-queue output dscp-map queue 4 threshold 1 8 9 11 13 15
mls qos srr-queue output dscp-map queue 4 threshold 2 10 12 14
mls qos queue-set output 1 threshold 1 100 100 50 200
mls qos queue-set output 1 threshold 2 125 125 100 400
mls qos queue-set output 1 threshold 3 100 100 100 400
mls qos queue-set output 1 threshold 4 60 150 50 200
mls qos queue-set output 1 buffers 15 25 40 20
mls qos
*****sample interface*****
interface GigabitEthernet1/0/3
switchport access vlan 200
switchport mode access
switchport voice vlan 201
srr-queue bandwidth share 1 30 35 5
queue-set 2
priority-queue out
mls qos trust dscp
no cdp enable
spanning-tree portfast
And I just want it to convert to be used in our new C9200L.  I've read a couple of articles including this one.. https://edennington.wordpress.com/2013/08/09/simplified-qos-on-3850-with-mqc/
However, I am still stuck at the moment.
I am hoping someone also had this experience and would be kind enough to share how they were able to convert this MLS to the new MQC in C9200L.
Atb,
Stressed Helpdesk
Your using standard MLS there so just use standard Auto Qos on the 9200
i have it deployed it works fine , run this under your access and uplink ports
auto qos trust dscp
It will then generate this in global config , which covers most standards , you could then if you wanted alter it too
class-map match-any AutoQos-4.0-Output-Multimedia-Conf-Queue
match dscp af41 af42 af43
match cos 4
class-map match-any system-cpp-police-topology-control
description Topology control
class-map match-any system-cpp-police-sw-forward
description Sw forwarding, L2 LVX data, LOGGING
class-map match-any AutoQos-4.0-Output-Bulk-Data-Queue
match dscp af11 af12 af13
match cos 1
class-map match-any system-cpp-default
description DHCP Snooping, EWLC control, EWCL data
class-map match-any system-cpp-police-sys-data
description Learning cache ovfl, Crypto Control, Exception, EGR Exception, NFL SAMPLED DATA, RPF Failed
class-map match-any AutoQos-4.0-Output-Priority-Queue
match dscp cs4 cs5 ef
match cos 5
class-map match-any system-cpp-police-punt-webauth
description Punt Webauth
class-map match-any AutoQos-4.0-Output-Multimedia-Strm-Queue
match dscp af31 af32 af33
class-map match-any system-cpp-police-l2lvx-control
description L2 LVX control packets
class-map match-any system-cpp-police-forus
description Forus Address resolution and Forus traffic
class-map match-any system-cpp-police-multicast-end-station
description MCAST END STATION
description Transit Traffic and MCAST Data
class-map match-any system-cpp-police-l2-control
description L2 control
class-map match-any system-cpp-police-dot1x-auth
description DOT1X Auth
class-map match-any system-cpp-police-data
description ICMP redirect, ICMP_GEN and BROADCAST
class-map match-any system-cpp-police-stackwise-virt-control
description Stackwise Virtual
class-map match-any system-cpp-police-control-low-priority
description General punt
class-map match-any non-client-nrt-class
class-map match-any system-cpp-police-routing-control
description Routing control
class-map match-any system-cpp-police-protocol-snooping
description Protocol snooping
class-map match-any AutoQos-4.0-Output-Trans-Data-Queue
match dscp af21 af22 af23
match cos 2
class-map match-any system-cpp-police-dhcp-snooping
description DHCP snooping
class-map match-any system-cpp-police-system-critical
description System Critical and Gold
class-map match-any AutoQos-4.0-Output-Scavenger-Queue
match dscp cs1
class-map match-any AutoQos-4.0-Output-Control-Mgmt-Queue
match dscp cs2 cs3 cs6 cs7
match cos 3
policy-map AutoQos-4.0-Output-Policy
class AutoQos-4.0-Output-Priority-Queue
priority level 1 percent 30
class AutoQos-4.0-Output-Control-Mgmt-Queue
bandwidth remaining percent 10
queue-limit dscp cs2 percent 80
queue-limit dscp cs3 percent 90
queue-limit dscp cs6 percent 100
queue-limit dscp cs7 percent 100
queue-buffers ratio 10
class AutoQos-4.0-Output-Multimedia-Conf-Queue
class AutoQos-4.0-Output-Trans-Data-Queue
class AutoQos-4.0-Output-Bulk-Data-Queue
bandwidth remaining percent 4
class AutoQos-4.0-Output-Scavenger-Queue
class AutoQos-4.0-Output-Multimedia-Strm-Queue
class class-default
bandwidth remaining percent 25
queue-buffers ratio 25
policy-map system-cpp-policy
class system-cpp-police-control-low-priority
class system-cpp-police-dhcp-snooping
policy-map AutoQos-4.0-Trust-Dscp-Input-Policy
class class-default
set dscp dscp table AutoQos-4.0-Trust-Dscp-Table
6 Replies 6
balaji.bandi
have you used cisco converter :
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-3850-series-switches/118629-technote-qos-00.html
what is the issue after deploying in to Cat 9200 ?
BB
auto qos trust dscp
match cos 4
match cos 1
match cos 5
match cos 2
match dscp cs1
match cos 3
class class-default
class class-default
Thanks so much for this @Mark Malone .. now at least I'm relieved, I thought the previous IT admin made some advanced QoS stuff to the switches.
So basically.. the below sample interface on the C2960XR below..
queue-set 2
priority-queue out
mls qos trust dscp
no cdp enable
Will now be equivalent to the below in the new C9200L switches..
interface GigabitEthernet4/0/1
switchport access vlan 230
switchport voice vlan 231
no cdp enable
auto qos trust dscp
service-policy input AutoQos-4.0-Trust-Dscp-Input-Policy
service-policy output AutoQos-4.0-Output-Policy
The service-policy lines automatically showed-up..
Again thanks so much for your quick response to this..
thats it you got it , you can easily test it on wireshark to make sure your phones get EF markings etc , but auto qos tends to work well at layer 2 level
I've tried to read this topic last night however still having problems understanding as I don't have much experience with QoS.. I think I can get it done, but would take me at least a week to read, understand and test for application.
No issues yet, I have not configured the C9200L switches yet.
Thanks so much for your update @balaji.bandi
You should be ok, any issue we can tweak the config required manner.
BB
