04-23-2022 07:23 AM - edited 04-23-2022 07:38 AM
I upgraded a couple of C3560CX's to 15.2(7)E6 recently. Its a routed access switch with three VLANs/SVIs - Data, Voice & Guest. The Guest SVI has an inbound ACL attached that permits DNS, DHCP and a couple of other things to the LAN. There is then a "deny ip any 192.168.0.0 0.0.255.255 log" and then a "permit ip any any". The logic being if its not an 802.1x authenticated corporate device it should drop onto the Guest VLAN that has restricted access to the local LAN, but can get out to the Internet.
It no longer works after I installed 15.2(7)E6 - the Guest devices have full access, apart from to the actual switch - i.e. I can't ping any of the interfaces on the switch, however any IP traffic through the switch works. I am fairly sure this didn't work on the last release (15.2(7)E5). However I haven't downgraded to check yet.
This feels like a fairly fundamental bug in this release? Its a common release for C2960X & C1000 series catalysts.
I don't see this behavior on C3560X's running 15.2(4)E10.
Anyone else seen this?
04-23-2022 08:44 AM
""The logic being if its not an 802.1x authenticated corporate device it should drop onto the Guest VLAN that has restricted access to the local LAN, but can get out to the Internet.""
Are you sure the Guest get Guest VLAN not other VLAN ?
04-23-2022 09:41 AM
if this working as expected, what is the reason for an upgrade, (the new version may have bugs,) so engage with TAC?
04-23-2022 09:49 AM - edited 04-24-2022 01:16 AM
Different switches. I have some older 3560X & 3750X series running 15.2(4)E10 and it works as expected on these. This 3560CX is newer and runs newer IOS. Just downgraded to 15.2(7)E5 and the behaviour is the same. Not sure how I missed this. These were upgrades from some 3560-8Ps which run 15.0 and these also worked as expected.
The device is definitely getting assigned to the guest vlan.
04-23-2022 10:51 AM
There may be something changes from version to version, sometimes recurring bugs we see, since the upgrade issue, I suggest to TAC is the best person to investigate, it also helps TAC fix in a future release the feature was not working as expected.
04-23-2022 10:57 AM
My opinion there is something missing or misconfig in 802.1x not bug.
04-23-2022 11:31 AM
If I remove all the dot1x stuff and just put the interface as an access port in the guest vlan the behaviour is the same.
I have done a chunk of troubleshooting prior to asking the question in here....
The issue is the ACL attached to the SVI doesn't work.
04-23-2022 04:04 PM - edited 04-23-2022 04:35 PM
Switch# sh platform acl interface vlanX <-guest VLAN
Input Label: 1
Output Label: 0 (default)
then
Switch# sh platform acl label 1 detail
can You share the output of last command,
04-23-2022 03:42 PM
Hello
Can you post the config of SVI and ACL please or even the run config of the switch
04-24-2022 12:58 AM - edited 04-24-2022 01:02 AM
cat-3560cx-12-1#sho platform acl interface vlan 310
Input Label: 1
Input IPv6 Label: 0 (default)
Output IPv6 Label: 0 (default)
cat-3560cx-12-1#sho platform acl label 1 detail
IPv4/MAC ACL label
Allocated L4 Ops: dst range 67 68, src gt 1023, dst range 16384 32767,
dst range 10000 20000, src range 8008 8009, src range 32768 61000
Input Op Select Index 0:
Output Op Select Index 255:
Input Features:
Interfaces or VLANs: Vl310
Vlan Map: (none)
Access Group: Guest, 30 VMRs.
Mask:
00008301 00000000 00000000 00000000 00000000 06587D58
Value:
00008201 00000000 00000000 00000000 00000000 00008301 Result: 0x04
Mask:
00008300 00400000 00000000 00000000 00000000 00000000
Value:
00008100 00400000 00000000 00000000 00000002 00000000 Result: 0x09
Mask:
00008300 00000000 FFFFFF00 FFFFFFFF FFFF0000 00000000
Value:
00008100 00000000 0A636300 C0A86414 00350002 00000000 Result: 0x09
Mask:
Value:
00008100 00000000 0A636300 C0A86685 00350002 00000000 Result: 0x09
Mask:
Value:
00008100 00000000 0A636300 C0A8780E 11940002 00000000 Result: 0x09
Mask:
Value:
00008100 00000000 0A636300 C0A8780E 01F40002 00000000 Result: 0x09
Mask:
00008300 FE000000 FFFFFF00 FFFFFFFF 00000000 00000000
Value:
00008000 32000000 0A636300 C0A8780E 00000002 00000000 Result: 0x09
Mask:
00008300 00000000 FFFFFF00 00000000 FFFF0000 00000000
Value:
00008100 00000000 0A636300 00000000 007B0002 00000000 Result: 0x09
Mask:
00008300 00010000 FFFFFF00 FFFFFFFF FFFF0000 00000000
Value:
00008200 00010000 0A636300 C0A86423 00500002 00000000 Result: 0x09
Mask:
Value:
00008200 00010000 0A636300 C0A86414 01BB0002 00000000 Result: 0x09
Mask:
Value:
00008200 00010000 0A636300 C0A86685 01BB0002 00000000 Result: 0x09
Mask:
Value:
00008200 00010000 0A636300 C0A86651 01BB0002 00000000 Result: 0x09
Mask:
Value:
00008200 00010000 0A636300 C0A86423 01BB0002 00000000 Result: 0x09
Mask:
Value:
00008200 00010000 0A636300 C0A8964D 238C0002 00000000 Result: 0x09
Mask:
Value:
00008200 00010000 0A636300 C0A8964D 02030002 00000000 Result: 0x09
Mask:
Value:
00008200 00000000 0A636300 C0A86615 06980002 00000000 Result: 0x09
Mask:
Value:
00008200 00000000 0A636300 C0A86616 06980002 00000000 Result: 0x09
Mask:
Value:
00008200 00000000 0A636300 C0A864D2 20FB0002 00000000 Result: 0x09
Mask:
Value:
00008100 00000000 0A636300 C0A86612 13C40002 00000000 Result: 0x09
Mask:
00008300 00000000 FFFFFF00 FFFFFFFF C0000000 00000000
Value:
00008100 00000000 0A636300 C0A86612 40000002 00000000 Result: 0x09
Mask:
Value:
00008200 00000000 0A636300 C0A86426 00500002 00000000 Result: 0x09
Mask:
Value:
00008200 00000000 0A636300 C0A866A2 0C380002 00000000 Result: 0x09
Mask:
Value:
00008200 00000000 0A636300 C0A866A5 0C380002 00000000 Result: 0x09
Mask:
Value:
00008200 00000000 0A636300 C0A866A6 0C380002 00000000 Result: 0x09
Mask:
00008300 00100000 FFFFFF00 FFFF0000 00000000 00000000
Value:
00008100 00100000 0A636300 C0A80000 00000002 00000000 Result: 0x09
Mask:
00008300 0000FFFE FFFFFF00 FFFF0000 00000000 00000000
Value:
00008200 00001F48 0A636300 C0A80000 00000002 00000000 Result: 0x09
Mask:
00008300 00200000 FFFFFF00 FFFF0000 00000000 00000000
Value:
00008100 00200000 0A636300 C0A80000 00000002 00000000 Result: 0x09
Mask:
00008044 00000000 FFFFFF00 FFFF0000 00000000 00000000
Value:
00008044 00000000 0A636300 C0A80000 00000000 00000000 Result: 0x05
Mask:
Value:
00008040 00000000 0A636300 C0A80000 00000000 00000000 Result: 0x07
Mask:
00008000 00000000 00000000 00000000 00000000 00000000
Value:
00008000 00000000 00000000 00000000 00000002 00000000 Result: 0x09
L4Ops: dst range 67 68, src gt 1023, dst range 16384 32767,
Multicast Boundary: (none), 0 VMRs.
uRPF : (none), 0 VMRs.
MDNS : (none) portlabel 0
Output Features:
Bridge Group Member: no
Vlan Map: (none)
Access Group: (none), 0 VMRs.
IPv6 ACL label
Input Op Select Index 255:
Input Features:
Traffic Filter: (none), 0 VMRs.
uRPF ACL:
uRPF ACL : (none), 0 VMRs.
MDNS V6 : (none) portlabel 0
Output Features:
cat-3560cx-12-1#
cat-3560cx-12-1#sho run int vl 310
Building configuration...
Current configuration : 289 bytes
interface Vlan310
description Cat-3560cx-12-1-office-Guest
ip address 10.99.99.78 255.255.255.240
ip access-group Guest in
ip helper-address 192.168.100.25
ip helper-address 192.168.102.25
no ip redirects
no ip proxy-arp
ip verify unicast reverse-path
ip pim sparse-mode
end
cat-3560cx-12-1#sho access-lists Guest
Extended IP access list Guest
10 permit ip any 10.99.99.0 0.0.0.255
20 permit udp any any range bootps bootpc (6 matches)
30 permit udp 10.99.99.0 0.0.0.255 host 192.168.100.20 eq domain (20 matches)
40 permit udp 10.99.99.0 0.0.0.255 host 192.168.102.133 eq domain (20 matches)
50 permit udp 10.99.99.0 0.0.0.255 host 192.168.120.14 eq non500-isakmp
60 permit udp 10.99.99.0 0.0.0.255 host 192.168.120.14 eq isakmp
70 permit esp 10.99.99.0 0.0.0.255 host 192.168.120.14
80 permit ahp 10.99.99.0 0.0.0.255 host 192.168.120.14
90 permit udp 10.99.99.0 0.0.0.255 any eq ntp
100 permit tcp 10.99.99.0 0.0.0.255 gt 1023 host 192.168.100.35 eq www
110 permit tcp 10.99.99.0 0.0.0.255 gt 1023 host 192.168.100.20 eq 443
120 permit tcp 10.99.99.0 0.0.0.255 gt 1023 host 192.168.102.133 eq 443
130 permit tcp 10.99.99.0 0.0.0.255 gt 1023 host 192.168.102.81 eq 443
140 permit tcp 10.99.99.0 0.0.0.255 gt 1023 host 192.168.100.35 eq 443
150 permit tcp 10.99.99.0 0.0.0.255 gt 1023 host 192.168.150.77 eq 9100
160 permit tcp 10.99.99.0 0.0.0.255 gt 1023 host 192.168.150.77 eq lpd
170 permit tcp 10.99.99.0 0.0.0.255 host 192.168.102.21 eq 1688
180 permit tcp 10.99.99.0 0.0.0.255 host 192.168.102.22 eq 1688
190 permit tcp 10.99.99.0 0.0.0.255 host 192.168.100.210 eq 8443
200 permit udp 10.99.99.0 0.0.0.255 host 192.168.102.18 eq 5060
210 permit udp 10.99.99.0 0.0.0.255 host 192.168.102.18 range 16384 32767
220 permit tcp 10.99.99.0 0.0.0.255 host 192.168.100.38 eq www
230 permit tcp 10.99.99.0 0.0.0.255 host 192.168.102.162 eq 3128
240 permit tcp 10.99.99.0 0.0.0.255 host 192.168.102.165 eq 3128
250 permit tcp 10.99.99.0 0.0.0.255 host 192.168.102.166 eq 3128
260 permit udp 10.99.99.0 0.0.0.255 192.168.0.0 0.0.255.255 range 10000 20000
270 permit tcp 10.99.99.0 0.0.0.255 range 8008 8009 192.168.0.0 0.0.255.255
280 permit udp 10.99.99.0 0.0.0.255 range 32768 61000 192.168.0.0 0.0.255.255
290 deny ip 10.99.99.0 0.0.0.255 192.168.0.0 0.0.255.255 log
300 permit ip any any (115 matches)
cat-3560cx-12-1#I know the source mask in the ACL doesn't match the subnet of the interface, however it covers it - 10.99.99.0/24 covers 10.99.99.64/28.
04-24-2022 08:35 AM
Hi there is some bug with guest VLAN, but it not for this IOS ver.
But let try one think,
I think that you config guest VLAN as aaa authentication failed or critical can you remove this line and test by connect client to VLAN access port.
04-24-2022 02:03 PM
Yes, I did a simple port config with just 'switchport access vlan 310' and the behaviour is the same. Its the ACL on the SVI that isn't working as expected.
I'm fairly sure this is a bug and its been there a while. The older C3560X switch I have works as expected with the same config (different SVI IPv4 address - 10.99.99.0/27, however the same ingress ACL) . The output to the 'show platform acl label x detail' on the C3560X running 15.2(4)E10 looks the same as the C3560CX.
I don't have support on either of these C3560CX's so TAC isn't an option unfortunately.
04-25-2022 01:59 AM
OK. So playing around with this a bit more and it looks like the dot1x configuration is somehow interfering.
I am sure I did this last week and it worked as I described, however that could have been with the 15.2(7)E6 and I've since downgraded this switch to 15.2(7)E5.
If I just put the access port into the Guest VLAN and remove all the dot1x configuration it works as expected and the traffic is denied by the ACL attached to the SVI. If I apply the dot1x config and stop the supplicant on the PC so it fails authentication and gets assigned to the Guest VLAN the traffic bypasses the ACL.
This is an IBNS 1.0 configuration. The interface configuration and the output to some of the dot1x stuff is attached below.
interface GigabitEthernet1/0/3
description docking-station
switchport access vlan 300
switchport mode access
switchport nonegotiate
switchport voice vlan 305
switchport port-security maximum 3
switchport port-security maximum 2 vlan access
switchport port-security maximum 1 vlan voice
switchport port-security violation restrict
switchport port-security aging time 3
switchport port-security aging type inactivity
no logging event link-status
srr-queue bandwidth share 1 70 25 5
srr-queue bandwidth shape 3 0 0 0
priority-queue out
ipv6 nd raguard attach-policy host-policy
ipv6 snooping attach-policy policy1
ipv6 dhcp guard
authentication event fail retry 1 action authorize vlan 310
authentication event server dead action authorize vlan 310
authentication event no-response action authorize vlan 310
authentication event server alive action reinitialize
authentication port-control auto
authentication periodic
authentication timer reauthenticate server
authentication violation replace
mab
no snmp trap link-status
dot1x pae authenticator
spanning-tree portfast edge
service-policy input IPPHONE+PC-BASIC
ip verify source smartlog
ip verify source
ip dhcp snooping limit rate 100
cat-3560cx-12-1#sho authentication sessions interface gigabitEthernet 1/0/3 details
Interface: GigabitEthernet1/0/3
MAC Address: e8d8.d1ee.dd76
IPv6 Address: Unknown
IPv4 Address: 10.99.99.72
User-Name: e8d8d1eedd76
Device-type: Microsoft-Workstation
Status: Authorized
Domain: UNKNOWN
Oper host mode: single-host
Oper control dir: both
Session timeout: N/A
Restart timeout: N/A
Periodic Acct timeout: N/A
Session Uptime: 312s
Common Session ID: C0A8FFF80000002008F4AF72
Acct Session ID: 0x00000013
Handle: 0xB400000D
Current Policy: POLICY_Gi1/0/3
Local Policies:
Service Template: GUEST_VLAN_Gi1/0/3 (priority 150)
Vlan Group: Vlan: 310
Method status list:
Method State
dot1x Stopped
mab Stopped
cat-3560cx-12-1#sho service-template GUEST_VLAN_Gi1/0/3
Description : NONE
VLAN : 310
URL_Redirect URL : NONE
URL-Redirect Match ACL : NONE
Idle timeout : NONE
Absolute-Timer : NONE
Linksec Policy : NONE
Input Qos Policy : NONE
Output Qos Policy : NONE
SGT Value : NONE
cat-3560cx-12-1#sho policy-map type control subscriber POLICY_Gi1/0/3
POLICY_Gi1/0/3
event session-started match-all
10 class always do-until-failure
10 authenticate using dot1x retries 1 retry-time 0 priority 10
event authentication-failure match-first
5 class DOT1X_FAILED do-until-failure
10 activate service-template AUTH_FAIL_VLAN_Gi1/0/3
20 authorize
10 class AAA_SVR_DOWN_UNAUTHD_HOST do-until-failure
10 activate service-template CRITICAL_AUTH_VLAN_Gi1/0/3
20 authorize
30 pause reauthentication
20 class AAA_SVR_DOWN_AUTHD_HOST do-until-failure
10 pause reauthentication
20 authorize
30 class DOT1X_TIMEOUT do-until-failure
10 terminate dot1x
20 activate service-template GUEST_SUPP_VLAN_Gi1/0/3
30 authorize
40 class DOT1X_NO_RESP do-until-failure
10 terminate dot1x
20 authenticate using mab priority 20
50 class MAB_FAILED do-until-failure
10 terminate mab
20 activate service-template GUEST_VLAN_Gi1/0/3
30 authorize
70 class always do-until-failure
10 terminate dot1x
20 terminate mab
30 authentication-restart 60
event agent-found match-all
10 terminate mab
20 authenticate using dot1x retries 1 retry-time 0 priority 10
event aaa-available match-all
10 class IN_CRITICAL_VLAN do-until-failure
10 clear-session
20 class NOT_IN_CRITICAL_VLAN do-until-failure
10 resume reauthentication
event authentication-success match-all
10 activate service-template DEFAULT_LINKSEC_POLICY_SHOULD_SECURE
event violation match-all
10 replace
cat-3560cx-12-1#
04-25-2022 05:16 AM
OK. So I've got a workaround, however I still think this is a bug and I shouldn't need to apply this workaround.
If I apply the Guest ACL directly to the L2 switchport (regardless of whether its attached to the SVI) the logic works as long as the RADIUS server sends an ACL as a Cisco AV-pair as this will take precedence over the interface ACL (currently ip:inacl#10=permit ip any any). Users that drop onto the guest VLAN (failed or no supplication) hit the interface ACL.
