01-26-2021 07:01 PM
Top-C3560X-48P-E 2 units:
L3 mode, PVST, Downlink port Trunk, HSRP(vlan 10, 20, 30 ...)
OS version-15.2(4)E9
Sub-C9300-48P-A several groups:
L2 mode, RSTP, Uplink port TRUNK
OS version-16.12.4
L3#1
int vlan 10
ip address 192.168.109.2 255.255.255.0
standby 10 ip 192.168.109.1
standby 10 priority 105
standby 10 timers 3 4
standby 10 preempt
L3#2
int vlan 10
ip address 192.168.109.3 255.255.255.0
HSRP is operating with the above settings.
There is no work or topology change,
Often in L3 #2, HSRP goes into Active state and then goes into Standby state.
Attached PNG file (analyze HSRP packet through wireshark)
Normally, a problem occurs after sending and receiving hello packets every 3 seconds normally (all SVIs are the same).
No. In 120332, 120343, L3 #2 declares Active.
No. At 120359, L3 #1 sends a Coup packet to declare Active
No. At 120510, L3 #2 switches to Speak.
The above process (No. 120332~120510) took place within 1 second when looking at the time,
This causes the switch's HSRP Active/Standby to be switched.
Connected clients suffer ping loss.
Usually, hello timer and hold timer should be three times different.
However, we are using the service by adjusting hello 3 and hold 4 respectively.
In other buildings L3 #1,2 there is no problem with the same configuration.
Which part should we check?
Please help.
Solved! Go to Solution.
01-26-2021 07:08 PM
can you post below information :
show standby brief
what version of hsrp ?
do you have spanning tree configure ? what is the status of that VLANs?
wht other Logs you see on both the device when they go up and down ?
here is some tips for troubleshoot :
https://www.cisco.com/c/en/us/support/docs/ip/hot-standby-router-protocol-hsrp/10583-62.html
=====️ Preenayamo Vasudevam ️=====
01-26-2021 07:08 PM
show standby brief
01-26-2021 07:59 PM
Thank you for answer.
show standby brief-> Active/Standby is changed from L3 #1,2.
Normally, L3 #1 has Active on all VLANs.
what version of hsrp?
-> hsrp v1
do you have spanning tree configure?
-> L3 #1 PVST, spanning-tree vlan x,x,x,x priority 4096, backbonefast
L3 #2 PVST, spanning-tree vlan x,x,x,x priority 8192, backbonefast
L2 #1,2,3... RSTP, L3 #2 uplink-cost 100,000(block)
-> SVI protocol and link up are maintained.
what other Logs you see on both the device when they go up and down?
-> There is no up/down log.
L3 #1: Switch to Act->Std
L3 #2: Switch to Std->Act
As soon as the state transitions, it behaves just like below
L3 #1: Switch to Std->Act
L3 #2: Act -> Switch to Std
Thank
and reguards.
01-27-2021 04:15 AM
First suggestion is move immediate to HSRP v2 and monitor before we do anything else. (like spanningtree)
01-28-2021 03:58 PM
We can't switch to hsrp v2.
Only when the exact cause is identified can proceed.
I will refer to the guide document you gave me.
Thank you for your support.
01-27-2021 04:46 AM
Hello
Either way you say those timers are "working" for other devices they are still aggressive regards the 1 second interval between sending the hello and the hold timer threshold, what would require such a short hold interval?
Are you pushing large amounts of traffic?
Whata the cpu utilization of those switches?
Have you:
01-28-2021 04:01 PM
The hello/hold timer value is a result that has been verified to have a minimum switching time through numerous tests in advance.
All other building backbones are in operation with the same hello 3sec and hold 4sec configuration.
Traffic is in use around 1/10~3/10, and there is no problem with interlink and STP configuration between devices.
There are no physical problems either.
No OS bugs have been identified.
