12-13-2011 10:47 AM - edited 03-07-2019 03:52 AM
Hello
I have recently installed 4 3560 (WS-C3560X-48T-S) Switches. At first the switch comes up, indicating all connected ports with a green
LED. Whenever i unplug a cable and plug it back in, the status LED will stay off. The same thing happens when I push the mode button
and cycle throgh the different modes, i lose certain LEDs.
I'm using 12.2(53)SE2, another user reported the same issues under 12.2(55)SE1 .
As this is happening on 4 different devices and other users have reported the same problem, I don't think this is hardware-related.
Any Suggestions?
Best Regards,
Marco
12-13-2011 11:00 AM
Hi Marco,
When you plug back the cable (from working switch port), does the LED stays off forever? If so, did you chack the status of the port by logging/console to the switch? If the LED coming up but taking little longer- then you need to enable 'spanning-tree portfast'.
I guess Mode button has nothing to do with this. Check the below thread about the 'Mode' button..
https://supportforums.cisco.com/thread/2044208
Thx
MS
12-13-2011 12:37 PM
Errrr ... what does the CLI say? When the lights are off do the interface stay UP or are they down?
Can you post the output to the command "sh interface
12-13-2011 01:42 PM
Hello mvsheik123 and leolaohoo
Thanks for your replies.
I forgot to mention that all interfaces are working properly. Interface status is up/up,
they are forwarding normally, counters are showing load. The interfaces have portfast
enabled, the LED stays even after a few minutes.
I don't know whether this is a coincidence, but when i last tried only the right portion
(interfaces 25-48) quit blinking after pushing the mode buton. As these switches are
productive already, I couldn't afford to reload a switch and so try and reproduce
the behaviour.
Marco
12-22-2011 08:56 AM
All
Our local Cisco supplier has found out that this problem is indeed an IOS bug.
It only shows on certain production series of the 2950 and 3560 platforms.
Problem is solved in IOS 12.2(58)SE and onwards...
Cheers,
Marco
11-14-2016 10:29 PM
Hi Marco,
Do you remember the bug number?
Thank you
11-15-2016 09:58 AM
Sergey
I'm really sorry, but I don't have any more details on that case. It's been 5 years and I have changed company and even the country since...
Best,
Marco
